Type R LS swap
Old Mar 21, 2002 | 05:47 PM
vtecsiqt's Avatar
Default Type R LS swap
If I was going to put a 00 Type R swap in my 94 LS what do I use for axles/ shift linkage/ motor mounts/ and how will the Type R header bolt up to my cat also what do I need to hook up the Type R ecu with my LS wiring harness?
[Modified by vtecsiqt, 8:46 PM 3/22/2002]
Old Mar 21, 2002 | 06:12 PM
bikeboy80's Avatar
Default Re: Type R LS swap (vtecsiqt)
let me take a shot at this one, axles, shiftlinkage, and motor mounts will be the same, the r header i believe will be too short, but you can just get a little welding done and it will be fine, and the wire harness, im not so sure on, hope i could help a little
preetyboi06
Jul 17, 2009 09:57 AM
Dropped90Integra
11
Nov 30, 2004 01:56 PM
mycvc8u2
Jan 5, 2003 12:18 AM
