ITR cams vs BC3's?
ITR cams vs BC3's?
I currently have ITR cams in my B16A but I wanted to squeeze a little more power out of it without doing to much right now. It made 163whp with the ITR cams, AEBS IM, ITR throttle body, Megan header, and crush bent 2.5" exhaust. I was looking at the BC3's and I see that a lot of people are running these with the stock valvetrain. Im just wondering what you guys opinions are on these cams vs the ITR cams. I have the rev limiter set at 8100 so that I know I never over rev the motor. Think these cams would make a little more power over the ITR's? I don't want to hear anything like "you already have ITR cams, don't waste your money". Just want to know if they will make more power than ITR's. Thanks in advance
Re: ITR cams vs BC3's? (JaydemHondUH)
i would say the bc3 with a good tuner would help out
check these out
https://honda-tech.com/zerothread?id=1743041
http://www.inlinefour.com/budclubracsp5.html
this car did not start with itr cams but made 24 hp over stock
https://honda-tech.com/zerothread?id=1607997
check these out
Totally worth the upgrade in my opinion. Those BC3+'s cams are one of my favourite profiles available on the market today. You will see significant gains once your cams are degreed and you re-tune.
Note: I would upgrade my valvetrain.
Re: ITR cams vs BC3's? (Chillinit)
Yes you would see some gains over the ITR's.
Although...you need to be running AT LEAST ITR OR CTR VALVE TRAIN in your b16 to run the BC3's. I couldn't imagine how long these would last on stock valve train.
Hope that helps homie.
Peace.
Peace.
