h22a4 spun bearing
h22a4 spun bearing
i have a h22a4 with spun rod bearing on #3. Is it worth fixing or should i just get another engine. if i could find a crank i could use it. cant find any h22a4 cranks except form honda they are 800$
i have a local shop that turns cranks he say .010 could clean it up but we cant find bearings to fit after machining
If any one knows where i can get the thicker bearings at i will have it turned
Re: h22a4 spun bearing (alterdcreations)
ok i am going to take my micrometer home from work to check the sizes i dont know the size of it yet. i do know the engine came from a 97 base model prelude
if it came out of a 1997 it has 50mm and you can use a h23 crank with h23 rods or ant h22 crank thats 97 and older. PM me if your interested i have a bunch of cranks from h22 and h23. cheap. Im in SC
Re: (KMaxwell)
the vin shows that it is a 97
is the 97 up h22a4 all open deck
i am very interested it the h23 stuff, i just want to know can i use my pistons on them since i have floating wrist pin. i own a machine shop so i can open the h23 rods up and bush them.
Modified by ashb82 at 6:07 PM 9/12/2007
i have oversized bearings if interested. i have .25mm oversizied and .050mm
and standard sizes. oversized are clevite bearings and the standard is acl
Re: (h22apwrdcivic)
no its definitly standard size bearings and undersize bearings. maybe thats why the op couldnt find bearings because he was searching for oversized not undersized. anytime u do a regrind on a crank u always use undersized bearings.
u measure the bearings by inside diameter. so if u take metal off of the crank than how does the inside diameter get bigger? it doesnt therefore the term undersized bearing because the inside diameter is smaller.
Re: h22a4 spun bearing (ashb82)
if taking .010 off would clean it up than i would do it and just get the according bearings. .010 isnt that much.
most bearing companys sell undersized bearings. i know for a fact acl sells undersized bearings up to .25. they may not advertise for them but they do sell them just call them up.
Re: h22a4 spun bearing (cartune network)
sorry i understand now. i was just thinking if the take off .010 my crank that would make my bearings .005 thicker. i understand now any way i got a good crank for 75$.I paid 50$ for engine and 75 for crank the guy even trew in the pistons and rods. h2b here i come
