Euro R/Type S H22A Red Top VS. JDM H22A Black Top (discussion dyno's inside)
I had the chance to get up close with building a Euro R CB Station Wagon. Not something you'd see every day. I am a H22A nut so I thought I would share the results. I will have the dyno sheet up shortly.
What the 3 cars have in common, same dynojet, roughly same temp out, same tuner, P28 Crome
-CB Accord 91 SW-
98 Euro R motor 12k miles, Factory PnP and port match,
- Euro R single runner manifold, appears to be 67mm TB from factory?
- Greddy Header 1.9" collector
- Greddy Touring Exhaust 1.9" collector then spreads to 60mm
- High Flow Cat.
- Manual Tensioner Conversion
- AEM 2.75" Short Ram Generic 3" filter
- H22A crank pulley with use of AC and PS
- P28 Crome Tuned
- 2 wire IACV, 345 cc OBD1 injectors, OBD1 Dizzy
- AC and PS have been calculated by the tuner to be a loss of 1.1 whp.
- ESP Front Torque Mount Kit Traction Bar System
191 whp 152 ft lbs of torque -dyno sheet up shortly-
Peaked out with Akimoto Flow Stack no filter 199.2 whp
8 whp gain with the flow stack was shocking
Vtec cracked nice on the Euro R...
-90 Honda Crx HF-
OBD 1 JDM H22A re ring 1k miles
- ESP H22A 4-2-1 Header 2" primaries down low 2.5" Collector
- 2.5" exhaust system
- 3" Short Ram Air Intake Generic filter
- P28 Crome Tuned
- 30k mill of the head roughly 10.9-1 compression
- Port Matched
- Secondaries hooked to Vtec
200 whp 168 ft lbs of torque
-89 Honda Crx SI-
HMO OBD1 JDM H22A Crate
- P28 Crome Tuned
- Secondaries hooked up to Vtec
204 whp 166 ft lbs of torque
Modified by ESP.net at 12:58 PM 10/31/2007
-CB Accord 91 SW-
- High Flow Cat.
- P28 Crome Tuned
-90 Honda Crx HF-
- P28 Crome Tuned
- Port Matched
-89 Honda Crx SI-
- P28 Crome Tuned
Re: Euro R/Type S H22A Red Top VS. JDM H22A Black Top (I smell secretions)
92 Chevron pump on all 3 Euro R had an additive but nothing crazy...
Once I get the sheet up it will show how the stock dual runner intake manifold is a decent manifold for stock to semi built builds, it's what makes the torque...
Re: Euro R/Type S H22A Red Top VS. JDM H22A Black Top (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">200+ whp on a stock H22 with a header? </TD></TR></TABLE>
Ive come damn close with a 100% stock engine...
Re: Euro R/Type S H22A Red Top VS. JDM H22A Black Top (2point6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 »</TD></TR><TR><TD CLASS="quote">
Ive come damn close with a 100% stock engine...</TD></TR></TABLE>
You've dyno'd 200 whp with a stock H22?
You've dyno'd 200 whp with a stock H22?</TD></TR></TABLE>
Uhmmm... I just post BS just because. Waste of time.
On a customers "bone stock" h22 he made 195hp and 155 tq... not 200hp, but "damn close".
my 98 USDM motor with euro r intake, custom 1/2greddy 1/2 custom header, 3 inch exhaust and 3inch cai made 192hp/151tq.
its curious on the euro r motor the intake made a difference.. i changed my intake and manifold and didnt find much difference at all.
How's it hard to believe 200whp out of an R motor rated 217 hp @ the flywheel? It makes sense to me. After all it does have some slight mods.
Re: Euro R/Type S H22A Red Top VS. JDM H22A Black Top (Televator)
one thing i forgot to ask.. why do you wire the secondarys to vtec?
take em out, you dont loose anything and pick up a little top end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Televator »</TD></TR><TR><TD CLASS="quote">How's it hard to believe 200whp out of an R motor rated 217 hp @ the flywheel? It makes sense to me. After all it does have some slight mods. </TD></TR></TABLE>
Am I the only one who read the thread or am I just retarded?
The "Euro R" motor is the only one that didn't make 200whp! The others are just your typical run of the mill JDM H22's.
^^.8 hp discrepancy. Forgive us....
- High Flow Cat.
- P28 Crome Tuned
Modified by Televator at 3:47 PM 11/1/2007
- High Flow Cat.
- P28 Crome Tuned
King of the One Liners
"Just 'cause it doesn't say "K" on the block doesn't mean it can't be done"
I like that.........
Re: Euro R/Type S H22A Red Top VS. JDM H22A Black Top (DC209)
I am still trying to get the sheet so we have something to discuss... bare with me...
Re: Euro R/Type S H22A Red Top VS. JDM H22A Black Top (ESP.net)
just for comparison sake... ask the guys at that dyno what some sort of stock honda makes on that dyno. a bone stock 07si makes about 175-180hp on my dyno
do you by chance have a dyno on the esp header that you guys make?
how does it compare to that of smsp or mugen?
so basically just having the simple i/h/e setup you had on the crx with the p28 gained you 204whp?
damn
makes me reconsider my set up
damn
Can't wait to see a comparison, and I heard the Euro-R has a big "final-gear". Thats why I got it, so I heard.......................Thanks
Re: Euro R/Type S H22A Red Top VS. JDM H22A Black Top (HondaCivicSiR1)
hearer is to small on the euro r.
its like comparing a b16b with a crap restrictive exhaust system to a bone stock b16a with some nice headers and bolt on's.
everyone know which block has the better potential in both cases, and its not the stock ones.
ESP-net
20
12-17-2006 08:39 PM
ESP-net
14
11-12-2006 10:22 AM
enigma94
01-14-2005 03:12 PM
