Ring Gap Question before assembly
GSR block: bored, decked, - 81.5 mm bore
- Piston-to-wall clearance: .004
- Wiseco 81.5 mm (B18C) pistons Part # K541M815
- Wiseco Rings (came with the pistons) Part #
Now my question is this. The machine shop told me that the rings came pregapped at 12thousands. What kind of actual gap should I be looking for? Also how far down in the sleeve do you put the rings to take the measurement. I plan on making 400-450hp on a turbo setup. I know wrong forum but you guys are more helpful
Re: Ring Gap Question before assembly
Check them yourself to see what they are. Only a feeler guage required. If the bore is round and has no taper you can check anywhere as long as the ring is squared. Use your turbo piston to push the ring down 1/2 inch and check. Doubt they are .012.
Wiseco recommends
Top ring 0.005Xbore
Second ring 0.0055Xbore
See link below
http://www.wiseco.com/Catalogs/Sport...ccessories.pdf
Top ring 0.005Xbore
See link below
Ring gap is dependent on bore size. Saying that they're "pre-gapped" suggests that they come gapped 'correctly' from the manufacturer.
thanks for the help guys. I called wiseco today and they gave me the correct ring gap to run at 20lbs of boost.
.017-.019 for top compression rings and .019 - .021 bottom compression rings
