good manifold and TB for race motor
I was considering using the jg manifold but have been told I will loose alot of power becuase its to large, is this true or not? and I was considering going with a 75mm TB should that be OK?
thanks
85mm, 14:1,nasty cams and more headwork than peter north
thanks
Re: good manifold and TB for race motor (ranta18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 »</TD></TR><TR><TD CLASS="quote">skunk2 or moddified factory manifold and str 70mm tb should do it.</TD></TR></TABLE>
Guest
Posts: n/a
Re: good manifold and TB for race motor (dumbshit)
port match b16/itr intake manifold, skunk 2 or if you want to be crazy ... ITB's, but the port match b16/itr or skunk 2 is good enough, and a 70mm TB is also good if you're going to go with the b16/itr or skunk 2 IM.
Re: good manifold and TB for race motor (96dxB16)
ITBs are way over rated, I do know that holland uses the jg piece and thats kind of what turned me on to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumbshit »</TD></TR><TR><TD CLASS="quote">ITBs are way over rated</TD></TR></TABLE>
They sure are.
They sure are.
Re: good manifold and TB for race motor (AussieB20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AussieB20vtec »</TD></TR><TR><TD CLASS="quote">ITR TB and IM</TD></TR></TABLE>
Ha ha. This head flows a bit better than that.
Ha ha. This head flows a bit better than that.</TD></TR></TABLE>
What size valves......
Re: good manifold and TB for race motor (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">A Ported ITR Manifold and 62-65mm (plate) Throttle Body can support any power you can reasonably make.
Suprdave</TD></TR></TABLE>
That's what I'm talking about. People are making 280whp with ITR IM's
DRAG_WORKX
04-04-2007 04:10 PM
