LS block build up for later LS/VTEC
Hey Guys and girls! I wanted you guy’s advice on a stoker kit for my B18B1 from an Integra 94. Here's what's going down. I want to install this stroker kit and later on install a B16 head with VTEC I’m told to get the Crank Shaft, Rods and skip the pistons and just get Civic Type R. and I should be near 2.1 L I just don't know where to get a good stroker kit, and I'm not sure but they said I might need to get the b16 head milled. So I want to make sure I have this setup where I don't need to get the head milled. I was hopping for Spoon or Jun parts but if it gets too expensive I'll take Eagle. For the most part I need help finding a place that sells the stroke kit for a good price. Maybe I'm getting too impatient but I want this thing in running before I do VTEC conversion. I'm still a little worried cause this motor is Frankenstein when I'm done it will be GSR tranny, LS block, Civic SI head, del sol A/C and power steering blah blah blah so I just want to get the stroked LS in before I do the VTEC I want all motor setup, so I'm going for high CR I'm still reading up on that though. If I need to get the B16 head milled I'll do it. Just want to keep cost down but want it done right.
Re: LS block build up for later LS/VTEC (skribblah)
It's alot of reading material, that's but I'm just looking for a quick answer. Where do you buy your stoker kits?
