average price on engine build
what is the avg price to throw in pistons, rods, head gasket, and studs? not including price for parts. just labor. i wanna know if 800 is good or bad.
Re: average price on engine build (JunIntegra)
depends on what all has to be done to the block to get these parts to fit. If there is a bore/hone that needs to be done, balancing, etc..
Re: average price on engine build (advanracing62)
if the your engine is already out the car and ready to get worked on, 800 bucks is way too much.
bore/hone doesnt cost alot. cost me around 40 bucks to do that when using std size 81mm.
probably around 100 bucks to do the pistons and rods.
headgasket, probably charge u a nickel and 2 dimes, cuz they have to slap on a headgasket anyways so they shouldnt charge u to use a new gasket.
theres a bunch of stuff u COULD do since the motor is already out.
1 Post
Re: average price on engine build (yeer)
800 is cheap if they are pulling the motor. Still cheap if machining is included...
At my Machine Shop, Bore\Hone\Jetwash is around $300...You gotta pay for quality work.
~700 is reasonable to have a motor pulled and put back in...$400-500 to have the motor assembled to spec, and ~200 is a nice round number for good machining...
$800 is cheap...
Suprdave
$800 is cheap...
Suprdave
Re: average price on engine build (Suprdave)
yes, the shop does everything. i bring the car, they take it from there, pulling motor and all. so i guess 800ish is good>?
Re: average price on engine build (omniman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omniman »</TD></TR><TR><TD CLASS="quote">oats always cost less after they pass through the bull.
time=quality and quality=money
i charge about 125-150 per cyl for complete short block assembly
considering the tools that measure and check the clearances in a motor can cost several thousand dollars. like the mitutoyo digital bore gauge set i use for measuring clearances (over 3k) .000001 accuracy. its not like you can buy a tape measure to do the job right. </TD></TR></TABLE>
I agree you get what you pay for.
Re: average price on engine build (TREVER)
time doesnt always equal quality, one of the mechanics at our shop does engine swaps with a fuel rebuild on semi's over 20 hours faster than they should be done, he is just super efficent, and he has never had a comeback..
Unseen Racer
17
02-06-2009 12:39 PM
fuck honda-tech
14
12-08-2003 03:52 AM
JICsube
01-23-2003 12:20 PM
