Torque Specifications for ARP headstuds in ls/vtec
What are the torque specifications when using gsr ARP headstuds in an ls/vtec with the molylube or regular oil? Thanx-Paul
Re: Torque Specifications for ARP headstuds in ls/vtec (tnsxsear1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnsxsear1 »</TD></TR><TR><TD CLASS="quote">What are the torque specifications when using gsr ARP headstuds in an ls/vtec with the molylube or regular oil? Thanx-Paul</TD></TR></TABLE> with the moly lube NO more than 70lbs... regular oil i belive it's 66ish
Re: Torque Specifications for ARP headstuds in ls/vtec (85mm LS VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* »</TD></TR><TR><TD CLASS="quote"> with the moly lube NO more than 70lbs... </TD></TR></TABLE>
Re: Torque Specifications for ARP headstuds in ls/vtec (DEVIOUS_EF*)
you have to use a 2 step sequence. I say u do the first opne at 26 and the second and final at 70. I just did mine yesterday .
Re: Torque Specifications for ARP headstuds in ls/vtec (Boost2NA)
the instruction sheet sais to disregard the stock specs,and to give the final torque of 75
foot lbs,but with aluminum application,end it with 65 ft lbs
so final answer---65 ft lbs with the lub----
