What is a "poor mans type r" or what they call "mini type r"?
Re: What is a "poor mans type r" or what they call "mini type r"? (poorman-type-r)
a 1.8 b series vtec block (gsr) and the b16 head (PR3). It's called a poor mans type r, because the ITR uses the same PR3 head, just with a mild hand port and polish and different valve train, and the block is a 1.8 vtec. I'm "kinda" doin a poor mans type r .. but it's a type r block with a b16 head
Re: What is a "poor mans type r" or what they call "mini type r"? (cmGSR916)
i was also under the assumption that it would also involve R cams and either an R intake mani or clone....
Re: What is a "poor mans type r" or what they call "mini type r"? (Odiedogcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">a 1.8 b series vtec block (gsr) and the b16 head (PR3). It's called a poor mans type r, because the ITR uses the same PR3 head, just with a mild hand port and polish and different valve train, and the block is a 1.8 vtec. I'm "kinda" doin a poor mans type r .. but it's a type r block with a b16 head </TD></TR></TABLE>
Wouldent you have to include pistons of some sort as well. Putting an si head on a gsr block would lose compression and in turn hp.
Re: What is a "poor mans type r" or what they call "mini type r"? (crxgsr91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 »</TD></TR><TR><TD CLASS="quote">
Wouldent you have to include pistons of some sort as well. Putting an si head on a gsr block would lose compression and in turn hp.</TD></TR></TABLE>
yes that is tru u would need to upgrade pistons
this would be pretty close to a "poor mans R" except, i have PR3 pistons
https://honda-tech.com/zerothread?id=1004094
i think if u put a PR3 pistons on ur "poor mans R" your cr will be a lil higher than using itr pistons...
make sure to change ur pistons if ur doin "poor mans R" if not ur cr will be 9:8...
i got "poor mans R" xcept im using JDM P30 pistons...n better valve train
yes it has potential...
Re: (cmGSR916)
It's no different really. LSVTEC you're making a 1.8 non vtec block to a vtec block ... stroke and compression would be the only differences ... ls having a longer stroke i, than the gsr/itr i believe.
vtec-power
11-28-2010 10:08 PM
