Milling
Banned
Milling
Im putting Crower stage 2 Vtec cams in my h22a head which is 10.6:1 stock. How much should I have the head milled for optimum compression to get as much power out of the cams as possible?
Re: Milling (MadnessRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadnessRacing »</TD></TR><TR><TD CLASS="quote">i wouldnt milled the head for nothing!!</TD></TR></TABLE>
wow
wow
Re: Milling (hybridvteceg)
Dont mill the head; Get a 2 layer HG and some flat face valves. thats good for raising your CR by almost 1 full point. 11.5:1 is good enough for prettty much any cam and pump gas.
Re: Milling (JoeB18R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeB18R »</TD></TR><TR><TD CLASS="quote">Dont mill the head; Get a 2 layer HG and some flat face valves. thats good for raising your CR by almost 1 full point. 11.5:1 is good enough for prettty much any cam and pump gas.</TD></TR></TABLE>
1 point is actually .1, so itd be 10.7 instead of 10.6 FYI. 10 points is 1.0
actually valves are more like 2-3 pts, and the hg all depends on which one you get and how thick it is. youd have to actually calculate the comp gain for the hg unless the mfg actually lists it for the specific app.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">actually valves are more like 2-3 pts, and the hg all depends on which one you get and how thick it is. youd have to actually calculate the comp gain for the hg unless the mfg actually lists it for the specific app.</TD></TR></TABLE>
Yeah more like .2-.3, and yeah thing head gasket compression ratio comes from calculation.
and milling isnt just good for raising compression, in some/most cases improves quench pad, and turbluence effect.
watch out for valves and pistons though, clay is your friend
-s
-s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">2 points is .2...lol</TD></TR></TABLE>
Oops meant to sound like i was agreeing with you.... lol
-s
-s
CrX-To-Tha-Max-v2.0
03-22-2005 01:58 PM
EGbeater
14
04-19-2004 09:04 AM
