can i run jun IIIs with my comp
i was searching around and i was wondering is ok to run jun III cams with about 11:0:1 compression or not. if you guys could answer that it will help me out thanks
i run Jun 3s in my JDM ITR. Runs good. Using 2 ply Spoon head gasket to bump up compression a bit. Havent got measured numbers but i estimate my compression to be about 11.6:1. Im pulling 146kw on a hub dyno.
Re: can i run jun IIIs with my comp (96tegls)
yes you can run 11.0 comp but they love more compression
I run 12.5 maybe slightly more with the 10 thou mill i had to do
it just doesnt run very well on pump gas
but then again we have 94 and 100 at the pump here so im ok
Re: (96tegls)
well you asked if you can run those cams with your setup...
however for best performance they work best with higher compressions
but when running more than 11.0 11.5 it gets tougher to run pump gas...
i am ok since we have 94 and 100 at the pumps...
