reusing pistons?
ive just spun a rod bearing on my b16a and amnow considering using the head for an lsvtec buildup. is it ok to reuse my pr3 pistons from the b16? i know fitment isnt an issue but im new to this and i dont want to throw in used pistons if thats a big no no. if its okay to reuse pistons what should i look for when inspecting them to see if they are still good..so far all i see is the normal carbon buildup on the tops. ill see how they look when i pull them out of the block
thanks in advance
thanks in advance
It's never a bad idea to give them a few quick measurements with a micrometer, but used pistons are great. while they're out, it's not a bad idea to balance them either. All you need is a grinder and a postal scale.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmaonade »</TD></TR><TR><TD CLASS="quote">i thought pr3 pistons bend after u take them off the rods making them unusable. anyone know of this?</TD></TR></TABLE>
That's a new one on me. I've seen plenty of sets of PR3's reused and never an issue. And based on build alone, if it was a problem with PR3's it would also be a problem with all other OEM B series pistons, but it's not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">????????????
That's a new one on me. I've seen plenty of sets of PR3's reused and never an issue. And based on build alone, if it was a problem with PR3's it would also be a problem with all other OEM B series pistons, but it's not.</TD></TR></TABLE>
yeah it was just somethign i've heard with pr3 pistons. that once you take them off the rod they bend and can't be reused.. i'll search on it
Just use your best judgment after you clean it.
