ls vtec conversion question on dowel pins
do u really need dowel pins and whats the purpose for them? if u do need them can u have the block assmebled why they drill the holes for the dowel pins. or will the dowel pins on the gsr head fit right on the ls block, i'm a noob to ls vtec so please excuse my ignorence
Re: ls vtec conversion question on dowel pins (vtecb20coupe)
Use the dowel pins, get the head machined, or but the ones from Golden Eagle. They are important.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe »</TD></TR><TR><TD CLASS="quote">you don't have to have the dowel pins. they are simply there to help making the alignment process easier.</TD></TR></TABLE>
The dowel pins ARE the "alignment process"!!!! Without the pins you cannot properly align the head.
Re: ls vtec conversion question on dowel pins (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">
The dowel pins ARE the "alignment process"!!!! Without the pins you cannot properly align the head. </TD></TR></TABLE>
yes, would you put on your main caps or rod bolts without the dowel pins?? critical to perfect alignment.
Re: ls vtec conversion question on dowel pins (philafelman)
i have the golden eagle kit and it came with pins but i have a gsr head goin on a b18a and for some reason its really hard for them to mate together...is there anu other pins i can use like oem ls or oem gsr??
limegreenneon
11-21-2003 04:03 AM
