How to find piston dome volume?
The chamber volume can be found with an inexpensive kit, but what abou the piston dome volume? Basically, you just need to know the cylinder bore, stroke, chamber volume, head gasket thickness, and piston to deck height to find the exact compression ratio. The only value I don't know is the piston dome volume.
Any ideas?
Here is a picture of them...
Any ideas?
Re: How to find piston dome volume? (ranta18)
i use file fit rings gapped to near zero. install the piston on the crank with lots of heavy grease on the cylinder walls to seal the rings completely. lower the piston exactly an inch and measure cc's to top of bore (making sure the dome is below the top of the bore). drop the piston to exactly two inches from the top of the bore and measure again. double your first measurement and subtract from the total of the second measurement, this would be your dome volume.
Re: How to find piston dome volume? (Bud's Machine)
Plans are to wrap a thin strip of aluminum around the piston. Put the piston 2cm below the aluminum edge. Place the clear plastic cover w/ hole in it over the metal edge. Take a reading of the liquid in the graduated cylinder. Pour the liquid onto the piston until it fills up. Take another reading. pi*(bore/2)^2*2cm - the amount of liquid used should be the dome volume. I'm just trying to get a general idea of the compression ratio +/- .2
Okay i place the piston in the cylinder block with the top rings insert and then turn the crankshaft to lower the piston an inch from the top of the cylinder bore .Then i grease the top of the block i place a peace of clear plastic plate with the hole in it and cover over the piston i use some green rubbing alcohol with a syringe to fill onto the piston until it fill take the reading that should be piston dome cc volume i'm just learning about piston dome volume
okay i place the piston in the cylinder block with the top rings insert i turn the crankshaft to level the piston dome to the top of the cylinder bore .Place clear plastic with the hole in it cover over the piston i use some green rubbing alcohol with a syringe onto the piston until it fills take the reading that should be dome volume i'm just learning about piston dome volume
