car not starting? iacv?
would a broken iacv not allow my car to start? or could it possibly be my ecu?
the car is cranking and sputtering, but no start, it started before i replaced the head gasket and swithched the IACV
if my ecu was fried would the car even try to turn over?
Re: car not starting? iacv? (JDMdc2lsVtec)
the CEL turns on and then off after i switch it to the accessories, when i jump the pin the CEL stays on
can i open my ecu up to see if it is fried?
damn car cranks but wont kick over, my fuel pressue guage reads 40 psi like normal so I dont believe I have a fuel problem
Re: car not starting? iacv? (Quick.Silver)
Can you hear your fuel pump kick in? If not you're ecu could have been fried. But I highly doubt it. Check to see if you have any spark. My car did that to. turns out my dizzy was out.
Re: car not starting? iacv? (NoLongerNA)
im not quite sure if it is the fuse, last time before the car last started last week the speedo started jumping then fell down, since then I replaced the head gasket
if it is the ecu can I open it up and visually see if it is fried?
Re: car not starting? iacv? (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">If I rermember correctly, the fuse for the VSS in the same as the altenator. Have you checked that?</TD></TR></TABLE>
im not quite sure where the fuse is, I dont have the fuse diagram because the person i bought the car from must have lost it
I woul like to check the fuse, does anyone have a diagram?
I believe i found the source of the poblem, the 2 wire plug that goes to the distributor, the black and yellow wire got fried so my dizzy i bought bought is worthless now
does anyone know what would cause this wire to fry? could it have been because my tranny ground wasnt connected?
it is now connected and I dont want to fry my LS dizzy, its the only one i have left, i have to chop the leg off to fit the GSR head but its all i have
I also had an MSD external coil
I am thinking it is spark because the car has ful pressue and when i was trying to crank it over the muffler pretty much farted and it smelt like un-burnt gas
do you think my GSR dizzy is ruined? or can i replace that wire? it doesnt have any crank position sensor, TDC and the other sensor in the dizzy codes showing up. I have an extra wire laying around and im sure i can take it apart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec »</TD></TR><TR><TD CLASS="quote">
fixed it
bad distributor
my car i a little smokey though, the smoke is not a thick white, blue, or black, its mostly clear with a little white like exhause that doesnt go trough a cat, think it might be running a little lean?
bad distributor
TexasRoller
08-15-2012 04:38 PM
trooper0641
02-01-2006 10:22 PM
JDMEK206
12-28-2005 10:22 AM
illestrolla247
04-04-2005 06:24 PM
