Code 20, ELD, need help fast!!!
Old May 22, 2006 | 08:54 PM
DC2 Mang's Avatar
Default Code 20, ELD, need help fast!!!
So when I first started my car last week my head gasket was on wrong so it sprayed oil every where and when I tried to start it again to see where it was coming from it wouldnt start, my Tach started bouncing up to 3 grand then I shut it off
I replaced the head gasket and tried starting it tonight and everything is hooked up, fully charged battery and it wouldnt start, then I threw up a code 20 for the ELD
I am thinking it is a blown fuse for for the Alternator/ speedo sensor because my tach bounced after the last time it started
where is the Alternator/ speedo fuse? because my fuse box's dont have the stickers on them
does anyone else know what could possibly be wrong and where I should check to fix the problem
all help is appreciated
Modified by JDMdc2lsVtec at 10:56 PM 5/22/2006
Old May 22, 2006 | 08:58 PM
B18 CYA's Avatar
Default Re: Code 20, ELD, need help fast!!! (JDMdc2lsVtec)
try a different fusebox, i had to change mine out and the code went away.
Old May 22, 2006 | 09:02 PM
DC2 Mang's Avatar
Default Re: Code 20, ELD, need help fast!!! (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">
try a different fusebox, i had to change mine out and the code went away.</TD></TR></TABLE>
which fuse box? the one in the car or in the engine bay?
it was working fine until the bouncing tach incident
Old May 22, 2006 | 09:16 PM
B18 CYA's Avatar
the one thats in your engine bay
i guess some cars have an eld and some dont? mine never had it and threw a code so a fusebox with one, and the code went away.
maybe something shorted in there? blown fuse? missing one?
Old May 22, 2006 | 09:30 PM
DC2 Mang's Avatar
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">the one thats in your engine bay
maybe something shorted in there? blown fuse? missing one?</TD></TR></TABLE>
yea, im about to go thhrough all of the fuses tomorrow
the person who had the car before me took the god damn stickers off
anyone know which ones to check first? VSS/ Alternator, main relay, grounds, o2 sensor, anything else?
Old May 22, 2006 | 09:54 PM
DC2 Mang's Avatar
anyone else?
Old May 23, 2006 | 05:29 AM
DC2 Mang's Avatar
bump
Old May 23, 2006 | 06:26 AM
DC2 Mang's Avatar
ttt
somebody help!
Old May 23, 2006 | 06:43 AM
92TypeR's Avatar
FSAE
If you are running a chipped ECU, simply dissable ELD using Crome.
Old May 23, 2006 | 10:41 AM
DC2 Mang's Avatar
Default Re: Code 20, ELD, need help fast!!! (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">If you are running a chipped ECU, simply dissable ELD using Crome.</TD></TR></TABLE>
good ****, ill do that
Old May 23, 2006 | 12:22 PM
DC2 Mang's Avatar
cant find the problem, i used 3 different ecus to try to start it
the battery light and check engine light are extremely dim, could this be due to a bad ground?
I just replaced the alternator but cant find the VSS/Alternator fuse in the fuse box
Old May 23, 2006 | 12:24 PM
DC2 Mang's Avatar
also my VAFC isnt turing on, could it be a poor connection with the engine harness or what?
i am totally stumped and pissed off about this
Old May 23, 2006 | 03:09 PM
DC2 Mang's Avatar
Old May 24, 2006 | 07:22 AM
Slamaccord's Avatar
double check all your conections sounds like a bad ground or something.
Old May 24, 2006 | 07:44 AM
DC2 Mang's Avatar
Default Re: Code 20, ELD, need help fast!!! (Slamaccord)
found it, it was a loose tranny ground
this is exactly why i dont like to wire cars with friends, they leave loose bolts that get looked over on the final visual inspection
would that loose ground cause my black and yellow distributor wire to get friend?
i believe the black and yellow wire is a ground for the coil and when i tried turning the key would it cause it to fry the wire?
Old Jul 29, 2006 | 10:49 AM
force-fed's Avatar
Default Re: Code 20, ELD, need help fast!!! (DC2 Mang)
ABS Control Unit (Coupe and Sedan): Right side of trunk, behind wheel well
ABS Control Unit (Wagon): Behind Right side of rear seat
ABS Modulator Solenoid Unit: Right rear corner of engine compartment, near under-hood fuse/relay box
ABS Motor: Right front of engine compartment, below battery
ABS Motor Relay: In under-hood ABS fuse/relay box
ABS Pressure Switch: Right front of engine compartment, below battery
A/C Compressor Clutch: Lower left front of engine, in A/C compressor assembly
A/C Compressor Clutch Relay: Left front corner of engine compartment, on inner fender panel
A/C Diode: Left front corner of engine compartment, taped to harness
A/C Pressure Switch (Dual): Left front of engine compartment, behind headlight
A/C Thermo Switch: Behind right side of dash, on A/C evaporator
Alternator: Lower left front of engine
Automatic Transmission Control Unit: On right front of floor, below carpet
Auxiliary Fuse Holder: On left kick panel, on right of under-dash fuse/relay box
Back-up Lights Switch: Center of engine compartment, on transmission
Blower Motor: Below right side of dash, in blower assembly
Blower Motor Relay: In under-dash fuse/relay box
Blower Motor Resistors: Below right side of dash, in blower assembly
Brake Fluid Level Switch: Left rear corner of engine compartment, in brake fluid reservoir cap
Brake Light Switch: Below left side of dash, on brake pedal support
Brake Light Sensor (Inner): Left rear of cargo area, in front of taillight
Brake Light Sensor (Outer): Right rear of cargo area
Bypass Solenoid: In engine compartment, below intake manifold
Chime: Behind left side of dash
Cigarette Lighter Relay: Behind left side of dash, near kick panel
Clutch Interlock Switch: Behind left side of dash, on clutch pedal support
Clutch Switch: Behind left side of dash, on clutch pedal support
Condenser Fan Motor: Left front of engine compartment, behind radiator
Condenser Fan Relay: Left front corner of engine compartment, on inner fender panel
Coolant Temperature Gauge Sender: Right front of engine, below distributor assembly
Coolant Temperature Sensor (TW): Right side of engine, below distributor assembly
Coolant Temperature Switch A: Right rear of engine, in coolant inlet
Coolant Temperature Switch B: Right side of engine, in coolant outlet
Countershaft Speed Pulser: Right rear of engine compartment, on transmission
Cruise Control Actuator: Left side of engine compartment, behind headlight
Cruise Control Unit: Behind left side of dash
Daytime Running Lights Control Unit: Behind left side of dash, next to kick panel
Dimmer Relay: In under-hood fuse/relay box
Disarm/Beep Switch: On lower left dash panel
Distributor Assembly: Right side of engine
Driver's Door Lock Switch Actuator: Inside lower rear of driver's door
Driver's Door Switch: In rear of driver's door jamb
Driver's Power Door Lock Actuator: Inside lower rear of driver's door
Driver's Power Window Motor: Inside lower front of driver's door
EGR Valve Lift Sensor: Top right of engine, forward of throttle body
Electric Load Detector Unit (ELD): In under-hood fuse/relay box
Electronic Air Control Valve (EACV): Top center of engine
Emission Control Box: Right rear of engine competent
Engine Oil Pressure Switch: Center rear of engine, above oil filter
Engine Mount Control Unit: Behind left side of dash
Engine Mount Control Solenoid Valve: Center rear of engine compartment, behind intake assembly
Fan Timer Unit: Behind Left side of dash
Front ABS Fail Safe Relay (Coupe and Sedan): Right side of trunk, behind wheel well
Front ABS Fail Safe Relay (Wagon): Behind right side of rear seat
Fuel Injectors: Top center of engine, at each intake port
Fuel Injector Resistors: Left side of engine compartment, forward of strut tower
Fuel Pump: Under maintenance access cover, below rear seat
Fuel Tank Unit: Under maintenance access cover, behind rear seat
Headlight Relay: In under-hood fuse/relay box
Heater Mode Control Motor: Behind center of dash, on heater assembly
Horn Relay: Behind left side of dash
Ignition Coil: Right rear of engine, behind distributor
Ignition Key Switch: Upper right side of steering column, on ignition switch assembly
Ignition Switch: Upper left side of steering column
In-Line Fuse Holder: Taped to harness, behind left side of dash
Intake Air Control Solenoid Valve: Right front corner of engine compartment, on inner fender panel
Intake Air Temperature Sensor (TA): Left rear of engine, on intake manifold
Integrated Control Unit: In under-dash fuse/relay box
Interlock Control Unit: Behind left side of dash, near kick panel
Junction Connector A: Ahead of left center pillar
Junction Connector B: Below left side of dash, near center console
Key Interlock Solenoid: Upper right side of steering column, on ignition switch assembly
Key Interlock Switch: Upper right side of steering column, on ignition switch assembly
Keyless Entry Control Unit: Under driver's seat
Left Front ABS Speed Sensor: On left front suspension knuckle
Left Rear ABS Speed Sensor: On left rear suspension knuckle
Left Brake Light Sensor: Left rear corner of trunk, on taillight assembly
Left Horn: Left front of car, behind bumper
Left Rear Door Switch: In rear of left rear door jamb
Left Rear Power Door Lock Actuator: Inside rear of left rear door
Left Rear Power Window Motor: Inside middle rear of left rear door
Lock-up Control Solenoid Valves: Right front of engine compartment, on transmission
Mainshaft Speed Pulser: Right front of engine compartment, on transmission
Moonroof "Close" Relay: Below left side of dash, above under-dash fuse/relay box
Moonroof "Open" Relay: Below left side of dash, above under-dash fuse/relay box
Moonroof Motor: Center rear of roof, above headliner
Oxygen Sensor (DX,LX): Center front of engine, in exhaust manifold
Oxygen Sensor (EX): Under center rear of engine compartment, in exhaust pipe
Parking Brake Switch: In console, at base of parking brake
PGM-FI Electronic Control Unit: On right front floor, below carpet
PGM-FI Main Relay: Behind left side of dash
Power Antenna Motor (Coupe and Sedan): Left side of trunk, behind wheel well
Power Antenna Motor (Wagon): Left rear of cargo area
Power Door Lock Control Unit (Coupe and Sedan): Front of driver's door
Power Door Lock Control Unit (Wagon): Under drivers' seat
Power Steering Switch: Lower left rear of engine compartment
Power Window Relay: In under-hood fuse/relay box
Radiator Fan Motor: Right front of engine compartment, behind radiator
Radiator Fan Relay: In under-hood fuse/relay box
Radio Noise Condenser: Top left side of rear tray
Rear ABS Fail Safe Relay (Coupe and Sedan): Right side of trunk, behind wheel well
Rear ABS Fail Safe Relay (Wagon): Behind right side of rear seat
Rear Window Defogger Relay: In under-dash fuse/relay box
Rear Window Washer Motor: Behind lower left corner of front bumper
Rear Window Wiper Motor: Center of tailgate
Recirculation Control Motor: Below right side of dash, on blower assembly
Remote Control Key Recharger: Upper right side of steering column
Right Brake Light Sensor: Right rear corner of trunk, on taillight assembly
Right Front ABS Speed Sensor: On right front suspension knuckle
Right Front Door Key Cylinder Switch: Upper rear of right front door
Right Front Door Switch: In rear if right front door jamb
Right Front Power Door Lock Actuator: Inside lower rear of right front door
Right Front Power Window Motor: Inside lower front of right front door
Right Horn: Right front of car, behind bumper
Right Rear ABS Speed Sensor: On right rear suspension knuckle
Right Rear Door Switch: In rear of right rear door jamb
Right Rear Power Door Lock Actuator: Inside rear of right rear door
Right Rear Power Window Motor: Inside middle rear of right rear door
Seat Belt Switch: Inside driver's seat belt buckle
Security Control Unit: Behind left side of dash
Security Flasher Relay: Behind left side of dash
Service Check Connector (C444 - 2-BLU): Below right side of dash, at kick panel
Shift Control Solenoid Valves: Lower right front of engine compartment, on transmission
Shift Lever Position Switch: Under left side of console, at base of gear selector
Shift Lock Solenoid: Under right side of console, at base of gear selector
SRS Control Unit: Below center of dash, below heater assembly
Starter: Right side of engine above transmission
Starter Cut Relay 1: Below left side of dash
Starter Cut Relay 2: Below left side of dash
Starter Solenoid: Right side of engine, above transmission
Tailgate Latch Assembly: Center of tailgate
Throttle Angle Sensor: Right rear of engine, behind throttle body assembly
Trailer Lighting Connector (C618 - 8-GRY) (Wagon): Left rear of cargo area, in spare tire compartment
Trailer Lighting Connector (C717 - 6-BLU) (Coupe and Sedan): Left side of trunk, top rear corner
Trunk Latch Switch: Rear of trunk lid, on trunk latch assembly
Turn Signal/Hazard Relay: In under-dash fuse/relay box
Under-dash Fuse/Relay Box: On left kick panel
Under-hood ABS Fuse/Relay Box: Right side of engine compartment, forward of strut tower
Vehicle Speed Sensor: Right rear of transmission
Windshield Washer Motor (Coupe and Sedan): Behind lower left corner of bumper
Windshield Washer Motor (Wagon): Behind lower left corner of front bumper
Windshield Wiper Motor: Left rear corner of engine compartment, under air scoop
Wiper Relay: Right rear corner of engine compartment, behind under-hood fuse box
Under-hood Fuse/Relay Box: Right rear corner of engine compartment, behind strut tower
Old Jul 29, 2006 | 03:51 PM
bluemax189's Avatar
Default Re: Code 20, ELD, need help fast!!! (force-fed)
thank you for posting that. There is no fuse for the ELD. Its built into the fuse box. my integra has a code showing for it, but the code alone wont trigger your CEL. Replace the ground wires.
Old Jul 29, 2006 | 05:13 PM
DC2 Mang's Avatar
Default Re: Code 20, ELD, need help fast!!! (bluemax189)
i fixed it quite a while ago, it was a loose tranny ground
Old Aug 3, 2006 | 05:36 PM
force-fed's Avatar
Yah I know u fixed the problem but u said someone took the sticker off ur fuse cover, I thought this might help for future problems
Old Aug 3, 2006 | 07:59 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by force-fed &raquo;</TD></TR><TR><TD CLASS="quote">Yah I know u fixed the problem but u said someone took the sticker off ur fuse cover, I thought this might help for future problems</TD></TR></TABLE>
good looking out
anyone know where i can get the sticke from?
Old Aug 4, 2006 | 12:45 PM
RedEj8's Avatar
Maybe you can get a new fuse box cover with the sticker on it from honda?
Glove
Sep 10, 2010 09:23 AM
RCJ0227
Acura TL, RL & ZDX
Jul 8, 2010 03:33 PM
DC2 Mang
May 23, 2006 06:27 AM
