Chicken or the egg?
Chicken or the egg?
Motor is a B16 stock block with blox b cams with omni valvetrain revving to 9200.
My question is simple what was destroyed first: valve or rod? The rod broke in half and the piston was completely chewed up. A few weeks earlier the engine was revved to 10500rpm by driver error.
I'm guessing rod since i was stock and 9200 was probably a bit too high. I knew this was going to happen someday, engine served my well for over 4 years of road racing.
Re: Chicken or the egg? (Ruben19)
a stock b16 revs to 8k stock. ive seen graphs of BC spec 3+ cammed b16's make power to 9k, im pretty sure that the much larger blox b's would hold power farther than 200 rpm over the stock redline
Re: Chicken or the egg? (JCushing)
skunk stage 2' make power around 8700 on b16's check !ll W!ll's build......
https://honda-tech.com/zerothread?id=1519846
man!! you guys are too REV HAPPY just like my brother in laws..thinking with just a couple of setups you can rev to 9-10000RPM???? you guys are crazy!! thats what happen when you don't do any research or know what the heck you guys are doing.
Re: (NA_B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B18C1 »</TD></TR><TR><TD CLASS="quote"> you can rev to 9-10000RPM???? you guys are crazy!! thats what happen when you don't do any research or know what the heck you guys are doing.</TD></TR></TABLE>
Thats a whole lotta RPM.
Anyway , as far as what failed first. If the valve failed first, usually it doesnt cause the rod to snap in half. The rod snapping in half definately could cause some valve problems on the other hand.
Secondly, as far as everyone reciting exactly where certain cams make peak power on certain engines, for these points to be valid at all, each engine would have to have identical heads (porting, VJ) compression, and bolt on's of the exact same brand, including engine management.
Re: (Combustion Contraption)
They definately hold power to 9000 rpm and even beyond! But i capped it 9200 because of the stock bottom end, which was still too high, i know.
It has a nasty dip at 6500, i've had that since i switched to a rage header from a DC4-1jdm. I was not able to tune that out. Rage gave me 8 hp more up top though. I didn't include the torque because it's in Nm and everybody would get confused.
The rod ends are not blue in any way. When it blew up i was at about 9000 rpm in second gear and then boom, a bit of smoke in the cabin and "a box of wrenches falling down some stairs", the end.
So to sum it up, it were probably the rods that failed. That's what i needed to know.
THEhomelessONE
08-26-2018 09:40 PM
ej_b16a
10-18-2016 09:26 AM
SuicideSlide
08-05-2003 02:13 PM
