Itr pistons and rods in a GSR block ????
what do i have to do to a gsr block to add type r pistons and rods
i will be using the stock gsr head and the stock gsr crankshaft
Basically..
Remove old pistons and rods.. get all your necessary materials..bearings..rings for the pistons.. WHATEVER YOU NEED.. And simply reverse the procedure, adding the new equipment as you go along.
Re: Itr pistons and rods in a GSR block ???? (eg4life1202)
will i have to bore the the sleeves in the us gsr block or are the new type r pistons and rods just drop in with new rings and bearings ???
i found a set of itr pistons with itr rods for a good price
i'm just looking to see if i can just hone the block and drop in the used set of itr rods and pistons with new rings and bearings
Re: (cherryhatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherryhatch00 »</TD></TR><TR><TD CLASS="quote">A friend of mine put c5 pistons in his c1 block with no boring. He could've been blowing smoke up my *** but I don't think he was. </TD></TR></TABLE>
no your friend is right no bore needed just <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherryhatch00 »</TD></TR><TR><TD CLASS="quote">Basically..
Remove old pistons and rods.. get all your necessary materials..bearings..rings for the pistons.. WHATEVER YOU NEED.. And simply reverse the procedure, adding the new equipment as you go along. </TD></TR></TABLE>
thats basically it
OH and for god sake do not forget to get your car re-tuned
thats basically it
Re: (cherryhatch00)
OH and for god sake do not forget to get your car re-tuned[/QUOTE]
I put c5 pistons and rods in my gsr block and didn’t get it tuned, and it runs fine, maybe a little rich, could that be why? And why would it need to be tuned? For gains or reliablity or just to have it run good? Because mine runs fine, just curious, thanks
I like the tuna here
You only *think* it's running fine. An engine is a complex assembly of parts rotating and moving at extremely high speeds synchronized with air, fuel, and spark operations that boggle the mind with the speed and accuracy of their split-second timing.
I can guarantee it is not running as well as it could, and that increases wear, decreases power, and shortens lifespan. If that's ok with you, then keep it how it is.
If its a virgin 81mm block with no issues a good hone would be fine, if the crank spun its always safe to over bore it to 81.5mm and use 81.5mm pistons.
You don't really have to but if you spun a bearing and the piston scored the walls your gonna have a shop pull your pistons out and repair the crank so having the walls over bored is always safe for a better seal as to re honing it that's all. i would reccomend going .010"/.25mm over just to get the cyl. straight and round cause it takes about .010" to clean up the cyl.
