im getting code 1 and 41 for Oxygen Sensor?!?!
Old May 2, 2004 | 12:19 AM
raider099's Avatar
Default im getting code 1 and 41 for Oxygen Sensor?!?!
i just did a swap.
92 auto dx
95 gsr motor
i had to extend the o2 sensor wiring longer.
i am not sure if i was getting the code before i extended the wiring but not after i cut the 4 wires and add lengh to them i get codes 1.
i then took out the o2 sensor and swapped it with another one i had, i also stripped all the tape on my extension to verify i matched the colors correctly, now i get a code 41. i did notice there was a white wire that looked shielded. when i extended it i did not shield it. is this necessary, does anyone know what else could be wrong here? thanks in advance.
criptic22
Jul 27, 2007 08:21 AM
BeavisB16
Apr 29, 2005 03:57 PM
dustinsterk
Dec 31, 2003 09:27 AM
1BadCvC
Oct 5, 2003 10:35 PM
VTEC-DA
Jul 30, 2003 05:55 AM
