94GSRswap into 98Ek
94GSRswap into 98Ek
I have a 98 EK Hatch, Im doing a 94 GSR swap in my car i have everything i need for the swap. I was wondering what problems i might run into? I know im gonna have a problem with my exhaust it either gonna be too long or too short. I was wondering if im gonna have a problem with the O2 sensors cause my car has 2 of them. I have a P72ECU that came out of a 98 GSR Teg. IF anyone has a done a swap like this could you please give me some inside on what problems might come up or what i need to do Thanks
Re: 94GSRswap into 98Ek (jayb98ek)
probably gonn have to swap out the fuel injectors and the distributor. Might have a problem with the crank angle sensor on the ecu...
when i swapped my 96 hatch with a 95 gsr the stock gsr header wouldnt bolt to my stock 96 piping. i had to get it extended at the muffler shop. i think u can use a older ls or gsr header and itll bolt up without the cat.. not sure though.
Re: 94GSRswap into 98Ek (b20_EK)
Are there any OBD II gsr motors? With the new inspection system they wanna set up here in nys, a obd I engine would not pass in the 99 hatch I am buying.
lilvpboijr2
12-01-2011 01:28 AM
