I am still a little confused
So I am getting a 96 or newer ls motor. I will be putting this in my 93 dx hatch. I think I need to get a p75 ecu and the obd2-obd1 conversion harness. What else am I gonna need. Will I need the 0bd1 dizzy, or any other obd1 parts. What about motor and tranny mounts can I just use the stock ones, or should I get the ones for the ls motor.
Re: I am still a little confused (b18bme)
you dont have to change any of the harness. the obd2 harness will plug straight up to the factory shock towers just get a computer for a 94-95 integra, and you should be set
Re: I am still a little confused (saleensolution)
So all I need to do is get the obd2 wiring harnes but use the obd1 ecu thats awesome what about other parts like a dizzy? Do I need to get the obd1 dizzy or will the obd2 dizzy work?
nah jus the ls compy, use a conversion harness *which mounts by ur ecu, u dont need all the wiring* if ur changin over the engine from obd2 to obd1 your car, got mine from JDMshit in 3 days i think thats it
