CA Bar Sticker question
Old Apr 29, 2004 | 12:00 PM
SamC's Avatar
Default CA Bar Sticker question
When is the bar sticker required? I know it would be need when doing a hybrid like a gsr engine in a civic. But what about a gsr engine into an integra rs, same body style; would a bar sticker be needed then? thanks
Old Apr 29, 2004 | 12:22 PM
3.3.3's Avatar
Default Re: CA Bar Sticker question (SamC)
if the smog shop you go to refers you to a state ref, that means you need a bar sticker. before they smog your car, they usually check the block code to see what chassis it falls into.
Old Apr 29, 2004 | 04:23 PM
SamC's Avatar
Default Re: CA Bar Sticker question (3 3 3)
I guess my question is if the chasiss and engine match but the vin number don't, then would a bar sticker be needed for smog? or is it solely up to the shop?
Old Apr 30, 2004 | 11:18 AM
3.3.3's Avatar
i am not sure if the smog shops will look at both vins. they might not. but if they do, then its automatically a red flag. then you go to the ref or CHP and they run the vins to make sure neither is stolen. they will then issue a replacement vin or just let it go.
Old Apr 30, 2004 | 06:12 PM
Colin's Avatar
legally, any time you change motors to a motor that is not the same motor that came in that car ("that" means your exact car, not just that body style). However you don't actually need a bar sticker until a smog shop notices that the engine is different and they refuse to smog you and send you to a ref. But yes, if you're putting a gsr engine into an rs, you need a bar sticker. Although who knows if the smog shop would actually notice.
hard_boiled_EG
Southern California
Apr 5, 2009 11:15 PM
sbpphoenix
Jun 11, 2008 07:27 PM
jeezyskillz
Jan 22, 2007 09:49 PM
92 BLUE EG6
Jun 15, 2006 02:57 AM
ShowtimesDC2
Sep 3, 2003 12:54 PM
