Prelude Engine Swap
Old Apr 30, 2004 | 11:53 AM
Phillip4288's Avatar
Default Prelude Engine Swap
Is it possible to swap a 2.2 liter prelude motor into a 94-95 honda civic?
Old Apr 30, 2004 | 12:18 PM
electric-boost's Avatar
Default Re: Prelude Engine Swap (Phillip4288)
yes its been done
wont handle to well without suspension tweeks
https://honda-tech.com/zero...08212
Old Apr 30, 2004 | 12:29 PM
Ricey McRicerton's Avatar
Default Re: Prelude Engine Swap (electric-boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electric-boost &raquo;</TD></TR><TR><TD CLASS="quote">yes its been done
https://honda-tech.com/zero...08212</TD></TR></TABLE>
It's only 25 lbs heavier than a B series swap. Don't post if you don't know. And look through the FAQ thread. There is tons of information about it on the first page. The engine is a H22, so look for H22 swap information.
Old Apr 30, 2004 | 12:31 PM
B16Drag's Avatar
actually its about 31 lbs heavier but whos counting...
and i second electric-boost on that it wont handle as well in terms of auto-x'ing
viet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phillip4288 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to swap a 2.2 liter prelude motor into a 94-95 honda civic?</TD></TR></TABLE>
yes.
go here y0, https://honda-tech.com/zeroforum?id=18
Old Apr 30, 2004 | 12:32 PM
Default Re: (B16Drag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Drag &raquo;</TD></TR><TR><TD CLASS="quote">actually its about 31 lbs heavier but whos counting...
and i second electric-boost on that it wont handle as well in terms of auto-x'ing</TD></TR></TABLE>
According to a thread on here the block was 2 lbs heavier and the tranny was 23 lbs heavier. Let me find it. Any facts to back up your 31 lb claim? You do realize that 31 lbs is the difference between a 130 lb girl and a 160lb guy friend right?
EDIT: The thread showing 25 lbs.
https://honda-tech.com/zerothread?id=684550
EDIT: We're both wrong! It's 35 lbs total. And it's 23 lbs more on the block.
B16Drag's Avatar
yes sir... some guy actually weighed them. cant find the thread or post but its 31lbs
i remembered this because i originally thought it was a tad bit more...
Old Apr 30, 2004 | 12:37 PM
Default Re: Prelude Engine Swap (Ricey McRicerton)
ok and how much heavier then a d-series? the fact is the civic was built around and suspension designed for the weight of a d-series motor not the b-series that your refering to which is still to general cause there are still 5 different types of b-series motor that all weigh different (though some not by much) . so if your gonna compare motor weight then do it between the d16 and the h22 and then we can talk
Modified by electric-boost at 4:48 PM 4/30/2004
Old Apr 30, 2004 | 12:42 PM
According to the same thread I linked to above
H = 123lb short block
B = 104lb short block
D = 100lb short block + oil pan
I don't know how much the D tranny weighs, but it's not a whole helluva lot.
Old Apr 30, 2004 | 12:49 PM
B16Drag's Avatar
Default Re: (Ricey McRicerton)
I'm closer! Give me a fry!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT: We're both wrong! It's 35 lbs total. And it's 23 lbs more on the block. </TD></TR></TABLE>
Old Apr 30, 2004 | 12:50 PM
well a complete drop out d series and complete dropout h22 have more than a 23lbs difference, i know you put shortblock but still its gonna weigh more, im gonna go weight them both in my garage hold on
Old May 2, 2004 | 02:10 PM
k guys........ lol 31 lbs it is.. thanks !!!
joshualynn07
Aug 11, 2006 11:43 AM
preludedude94
Oct 10, 2005 09:18 PM
rkwan82
Jul 3, 2004 04:38 PM
EFz6er
Feb 11, 2004 02:44 PM
HondataDemon
Jul 8, 2003 10:19 AM
