b16a into a 90 civic si shift linkage
Need to know where i can get a shift linkage for my 1990 civic si with a b16a swap done.. hasport doesnt offer it alone anymore. Do i get one out of an teg, and how much would i cut it? Would the cutting be different for each motor mount kit; like if they bolt in diff or what? Need to know asap please, car is finished waiting for this to get figured out.
Re: b16a into a 90 civic si shift linkage (litten)
You can use the 90-93 Integra linkage and modify (cut + weld) it to work. It's hard to say exactly how much to cut out but it's usually around 2". The best thing to do is cut the bars in half roughly in the center where they are straight, not in a bend. Then mount both bars to the tranny then the other side with the shifter installed to the floor. Then you can line them up kinda overlapping them to see exactly how much to remove. Just cut off the excess and reweld the bars together keeping them as straight as possible to avoid having the shifter alignment to be off.
MR CRX
11-04-2002 08:07 AM
