Mounts for b18c1 into 93 Civic hatch
Hello,
This is my first post
I just picked up a b18c1 GSR motor off Ebay to swap into my 93 Civic Si Hatchback.
The 2 upper motor mounts from the GSR are the only mounts in place. Can I use the 3 lower mounts from the Civic or do I have to find the Integra ones?
I am talking about the 2 'torque' mounts - the one on the front of the tranny and the other one between the AC compressor and block - and also the rear mount for the motor.
When looking at mounts for the engine swap it seems that there are only 3 mounts in a kit like the HaSport kit - the 2 upper ones and the lower rear.
Also, is there a good write up/how-to with all the vacuum hoses and sensors? I have seen a couple of write-ups like the one on C-speedracing but they don't show as much detail as I need.
TIA!
TIA!
Re: Mounts for b18c1 into 93 Civic hatch (xrdriver)
Mounts or Brackets? HEHEHE. You can use all the mounts you have in your hatch already MINUS the drivers side upper mount. You need the one that matches the engine generally. BRACKETS-The only one that you can use from your d series is the upper tranny bracket (which is part of the mount). The two front lower brackets you need to source from a 99-00 si or a 94+ integra. You also need a 99-00 si rear bracket.
As for the Hasport kit...The hasport kit doesnt require the lower brackets because the mounts are sooo stiff it compensates for em.
phelpsj2
02-22-2011 05:27 AM
