88 crx 94+ gsr motor...
hey whats up im doing a swap on my crx...im outting a gsr motor in it.. now what do i need??? swap comes with motor tranny ecu axles... i know i need custom mounts... but can i use stock gsr mounts? or crx mounts? also can i use the stock gsr shift linkage???? how do i wire up the vtec??? if u guys can help me it would be great... first swap..... thanx
Re: 88 crx 94+ gsr motor... (xjun10rx)
do a search on it, this topic has been covered extensively. but I can tell you you need custom mounts for b-series engine in hf body (88-91 civic crx). You'll need a conversion kit for a hydro tranny to cable, or get a cable tranny off a first gen b16a. you need custom shift linkage or I belive you can use one off a 90 integra. Check with HASport or HCP racing for most of these items. You'll also need custom axles to fit your hubs, check with raxles.com for these. Also you'll need to convert to obd1, you'll need a conversion harness to do obd0 to obd1.
Hope that helps!
Hope that helps!
RICeWhAt187
14
06-10-2006 06:11 PM
