Gsr engine in crx, can I run my obdo b16a alternator?
1 Post
Hi, I am swapping in a 95 gsr engine(obd1) in my crx, and the gsr engine came with a dented alternator pulley. Can my b16a alternator 0bd0 work? I would just swap the pulleys, but there is no leverage with hand tools. Last resort I will go to my friends shop, and use his air gun. Will it bolt over? Also, the plugs look the same, are they? Thanks so much, Ryan
Re: Gsr engine in crx, can I run my obdo b16a alternator? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">Hi, I am swapping in a 95 gsr engine(obd1) in my crx, and the gsr engine came with a dented alternator pulley. Can my b16a alternator 0bd0 work? I would just swap the pulleys, but there is no leverage with hand tools. Last resort I will go to my friends shop, and use his air gun. Will it bolt over? Also, the plugs look the same, are they? Thanks so much, Ryan</TD></TR></TABLE>
yes it will work
i have done it before with no problems
OBD two alt are different
yes it will work
1 Post
Re: Gsr engine in crx, can I run my obdo b16a alternator? (turbogixxer)
Sweet!!!!! Thats great. Ryan
ps, so no wiring diferences, and its the same plug, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">Sweet!!!!! Thats great. Ryan
ps, so no wiring diferences, and its the same plug, right?</TD></TR></TABLE>
same plug
obd zero has a extra wire but it will work with no problems
same plug
