to stroke or not to stoke
Old Apr 28, 2004 | 04:22 PM
2point0_lsvtec's Avatar
Default to stroke or not to stroke
i've searched this topic and have found a lot of info, but just want to hear what some of you guys would do. i'm building an ls vtec all street motor.
-b18a block
-sir full skunk head
i would also like to build up the bottom end. what would be the benifits of a large bore or a bigger stroke horsepower and reliability wise. something like a 85mm bore and 95mm stroke. would it be better to just go with a big bore.
Modified by 2point0_lsvtec at 6:24 PM 5/3/2004
Old May 3, 2004 | 09:26 AM
Default Re: to stroke or not to stroke (2point0_lsvtec)
is anyone here running a stroked ls vtec on the street?
Old May 3, 2004 | 04:03 PM
CompressionFed's Avatar
My new engine is 85X95. I will not be driving it on the street on a regular basis due to the compression.
If I were you, for a daily driven engine, I would just bore it to 85 and go from there. You can still get some great numbers with the 89mm crank!
Old May 3, 2004 | 10:46 PM
krazie1's Avatar
BANNED
Default Re: to stroke or not to stroke (CompressionFed)
i am running or was street driven 11:8:1 84mm by 95mm
and it pulled nicely for a sleeper u know
so I would resleeve first and then bore the **** but keep it under 12:5 the most if u want to stay on 93 octane
Old May 4, 2004 | 10:48 AM
what type of pistons are you running to keep it the compression under 12:1?
rdeezy78
Dec 7, 2006 03:21 PM
Spoonin
17
Dec 17, 2004 10:17 AM
shorto85
Aug 28, 2004 09:53 AM
escape2me
10
Apr 25, 2004 08:20 PM
allmotorEG-SI
Aug 27, 2002 07:34 AM
