no Vtec crossover.....
Old Apr 26, 2004 | 06:11 PM
its WANG yoO's Avatar
Default no Vtec crossover.....
i just put 98 Gsr swap in my 00' LS...i wired Vtec sel. and pressure switch to correct pins on my obd1 p72...i also wired knock sensor.....the thing is...at 4400...nothing happens...no crossover...i know i should be able to hear it and feel it...but nothing!
i wired my secondaries and they are opening at 5800 and boy..are they loud...so why wouldn't i hear/feel Vtec crossover? please help!
Old Apr 26, 2004 | 07:07 PM
Default Re: no Vtec crossover..... (inJDMtegra)
bump for night
Old Apr 26, 2004 | 08:43 PM
Mr Boston's Avatar
Are you getting any CELS? I've heard the GSR's vtec cross over isnt as prounced as other B series Vtec
Old Apr 27, 2004 | 02:42 AM
POWERLINEDOHCtor's Avatar
Default Re: no Vtec crossover..... (Clicky Pow)
(with the car not running) run power directly to the solenoid. check to see if it clicks. if it does, run a continuity check on the wire.
is your vtec oil press sensor wired and grounded correctly?
Old Apr 27, 2004 | 01:30 PM
Default Re: no Vtec crossover..... (POWERLINEDOHCtor)
no cels at all...pressure sensor is wired and grounded to the thermostat housing(the ground there)...i'll check to see if the seloniod clicks.
Old Apr 27, 2004 | 01:38 PM
selonoid is clicking...
Old Apr 28, 2004 | 12:34 AM
check continuity from pin A8 to the solenoid. and check oil level
Chpwhtek
Mar 19, 2012 04:48 PM
93delslow315
11
Dec 10, 2009 11:17 AM
631 Teggy
16
Mar 10, 2004 10:28 AM
bey
Nov 27, 2002 09:06 PM
shivic
Jul 7, 2002 05:50 AM
