B18C spec R wiring harness=B18C5 wiring harness???
I am swapping a B18C spec R in my 00 civic si. I need to know what wiring harness to use i have seen so many different answers to this question. I need to know exactly what will work in my car.??
Will my B16A2 harness work without modification?
Will a USDM B18C5 wiring harness work on the JDM engine?
Re: B18C spec R wiring harness=B18C5 wiring harness??? (B16AHondaSi)
You have to use your '00 si harness. This is the only harness that will work. Everything should plug right up but I believe you have to use a usdm vtec soleniod because the jdm one has no oil pressure switch.
Re: B18C spec R wiring harness=B18C5 wiring harness??? (allMotor93Hatch)
A USDM B18C5 engine harness will NOT work on your car beacause it is a two piece design.
Use your USDM SI engine harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16AHondaSi »</TD></TR><TR><TD CLASS="quote">I am swapping a B18C spec R in my 00 civic si. I need to know what wiring harness to use i have seen so many different answers to this question. I need to know exactly what will work in my car.??</TD></TR></TABLE>
You MUST use a 99-00 Civic harness, no other harnesses will work with your chassis without a lot of extensive wiring. Si and EX work without much modification and is pretty much all prewired for any DOHC VTEC setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16AHondaSi »</TD></TR><TR><TD CLASS="quote">Will my B16A2 harness work without modification?</TD></TR></TABLE>
That's the best and easiest solution, reuse your stock Si harness. You will have to change the IAT sensor plug, other than that everything should be plug and play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16AHondaSi »</TD></TR><TR><TD CLASS="quote">Will a USDM B18C5 wiring harness work on the JDM engine?</TD></TR></TABLE>
Yes it will, but not in your case.
wizzards581
10-21-2003 09:55 AM
