*NEW* B-Series LMA Info
Porting a head for a customer, I advised him to switch to the newer LMA style for his build (aftermarket cams, road racing, he was using the old tapered nipple style LMA's). I placed the order for the parts and went to pick them up. Apparently, Honda is no longer making the LMA we are all used to for the BVTEC heads, and instead have switched to the spring style as found in S2000, K-Family, and OBD2 Preludes. The old part # has been superceeded to 14820-PCB-305, which is NOT the same as the OBD1 Prelude w/ .040" washer trick, which was part # 14820-PCB-003. Below are some pics...
Old Vs. New
Height Measurement
Height Measurement
As you can see, they are roughly the same height, within a few thou which is within the range of acceptability due to the fact that I was taking the pics with one hand while holding the caliper with one hand and may have fudged the measurement just a bit. I will be doing a coil bind pressure test in the next few days , I'll update this thread when I do.
Old Vs. New
Height Measurement
Height Measurement
Re: *NEW* B-Series LMA Info (Combustion Contraption)
wow...interesting........you can even see there is a shim/washer at the bottom to take up the extra space.....
Re: *NEW* B-Series LMA Info (Adam@VisionaryAuto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adam@VisionaryAuto »</TD></TR><TR><TD CLASS="quote">Im kinda noob but is this new style better? If so how?</TD></TR></TABLE>
Havent done any hardcore testing, so I cant give a concrete answer, but if Honda went to this style for their advanced performance engines (H22A, K20A, F20C, F22C) its probably something worth looking at.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Godspeed07 »</TD></TR><TR><TD CLASS="quote">also noob question, but are they lighter???? if so would that even benefit the motor at all???</TD></TR></TABLE>
Yes, they are lighter. I dont have numbers. The force is pretty small , but if you subscribe to the "every little bit helps" club, maybe you will sleep better at night.
Re: *NEW* B-Series LMA Info (h46it)
Very interesting. I am curious to see how they will work. How much are they compared to the old lma's? I need to pick some up as soon as my head is back from NRGTech.
EDIT.....
$22.24 each at hondapartsdeals.com
http://www.hondapartsdeals.com...8&y=7
If anyone here can beat that price let me know.
Modified by 96Spec Ek at 12:26 AM 6/2/2008
Modified by 96Spec Ek at 12:27 AM 6/2/2008
EDIT.....
Re: *NEW* B-Series LMA Info (96Spec Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Spec Ek »</TD></TR><TR><TD CLASS="quote">Very interesting. I am curious to see how they will work. How much are they compared to the old lma's? I need to pick some up as soon as my head is back from NRGTech.</TD></TR></TABLE>
Yeah, how much, or which dealer did you score them from?
EDIT.....
Modified by 96Spec Ek at 12:27 AM 6/2/2008</TD></TR></TABLE>
$21.09 each at Majestic Honda assuming they are the newer style. Not sure, just looked them up for a 2000 Si.
EDIT.....
Re: *NEW* B-Series LMA Info (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe »</TD></TR><TR><TD CLASS="quote">$22 each? That's alot of coin.
Time to break out the CAD drawing board.</TD></TR></TABLE>
hell to the yea
hell to the yea
Re: *NEW* B-Series LMA Info (4GE4YA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4GE4YA »</TD></TR><TR><TD CLASS="quote">Isn't $22.00 still cheaper than the type r lma's?!?</TD></TR></TABLE>
Yeah I agree, they are still cheaper then the ITRs LMA going for $34-39 a pop
Re: *NEW* B-Series LMA Info (fastlifemotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastlifemotorsports »</TD></TR><TR><TD CLASS="quote">
Yeah I agree, they are still cheaper then the ITRs LMA going for $34-39 a pop</TD></TR></TABLE>
ya. in comparison, that's a good price. same as the older prelude's cost
Modified by Brick Top at 12:16 PM 6/30/2008
Re: *NEW* B-Series LMA Info (Brick Top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brick Top »</TD></TR><TR><TD CLASS="quote">
ya. in comparison, that's a good price. same as the prelude's cost </TD></TR></TABLE>
Expensive when compared to $7 cost for the S2000 and K-Series LMA's.
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
i noticed these in my '98 a4 head laying around. nice to know this info. thanks for posting this up.
