what igintion setup's is everyone using on n/a b16
I'm just wondering what everyone is using on there n/a b16's?
I'm currently using magnacore 8.5mm wires hooked up to stock dizzy and using ngk plugs, never seemed to have a missfire, wire's seem great.
I'd like to just see what everyone else runs and some comments on there experenice to help anyone else out.
All Motor Mentor
1 Post
Re: what igintion setup's is everyone using on n/a b16
not sure what you're really looking for since most people run whatever works for them. I'd say that most people run a similar setup to you except they may use a different brand of wires (everyone has their personal preference) and like you never really has any problems. If you start running some sort of crazy boost or a race motor, you'll probably change your ignition to meet the required needs but in most cases, on a mostly stock setup, what you're running is what everyone else is running.
are you using the "rocket" modified plugs?
i was thinking about trying that whole concept next dyno session.
i use stock with ngk plugs and wires.
You need to be making solid power before the STD setup needs changing.
Regards Uncle Dave
Regards Uncle Dave
thanks for the replys, figure it will help someone that's looking at peoples setups. But yeah my setup works extremly good and was about $100 dollars for wires and plugs. Only downside is you have to put the wires together your self, not a big deal unless you don't know how to do it.
CBR600OnTop
02-15-2003 10:35 PM
