LEAN Problems
Old Mar 15, 2004 | 05:06 PM
spoonek9's Avatar
Default LEAN Problems
92-95 JDM B16A coverted to obd2b running PCT(B16B) ECU. I have CTR piston, 70mm throttle body, and no cat. I think I'm running lean and I was wondering what would be a cheap fix for this. I've tried searching for info on injectors and I think my head is going to explode. Between peak and hold and saturated, I'm a little confused. I do have saturated injectors, correct (92-95 B16A)? If so, would Prelude injectors work? Which ones would I need? Any help is appreciated! Thanks
Old Mar 15, 2004 | 05:10 PM
eg6h8k's Avatar
Default Re: LEAN Problems (spoonek9)
get a fuel pressure reg...and guage..that should fix it..u dont have much mods so it should be enough w. out new injectors..if it doesnt fix it..well must be another problem..
seanevo3
Jul 29, 2017 02:24 AM
Kovatch EG
Jul 15, 2006 12:44 PM
fernruffryders
Oct 7, 2005 12:50 PM
wid326
May 4, 2004 02:52 PM
Turbohatch
Oct 2, 2001 11:26 AM
