D16Z6 complete rebuild quote....good or bad
Just wanted to get some feedback on whether or not this quote is a good price and also if the internals are matched well for a turbo (10psi +) application.
*Price are in CDN funds*
Labour
Rebuild engine $1000.00
Resurface head $60.00
Valve job $260.00
Resurface block $60.00
Bore and fit pistons $200.00
Resurface flywheel $65.00
Post block $325.00
Parts
Endyn pistons $850.00
Eagle rods $550.00
O.E.M. gasket kit $344.00
Main bearings $139.00
Rod bearings $96.00
Oil pump $152.00
Water pump $74.00
Timing belt $72.00
Total $5244 equivalent to $3813US
Labour
Valve job $260.00
Post block $325.00
Parts
Eagle rods $550.00
Rod bearings $96.00
Oil pump $152.00
Water pump $74.00
Timing belt $72.00
Re: D16Z6 complete rebuild quote....good or bad (SoCalude98)
With 4g's you can get a nice swap. Do you have all the turbo components already, if not then I would say get a swap. Less hassel and more potentail in the future!
Re: D16Z6 complete rebuild quote....good or bad (TwoRedEGgs)
you can do without the eagle rods and endyn pistons
i would just get oem replacement pistons and machines LS rods
post the block yourself, there is a DIY floating on the net, PM me if you cant find it
i would just get a new flywheel isntead of resufacing
a belt tensioner isnt mentioned there, your gonna need a new one too
valve job plus head cleaning seems to be what i'm gonna end up paying for it.
remember SOHC's are about DIY **** and work best with home made turbo's and what not...
i would just boost your current engine to 5-7 psi, wait till it blows, and buy a new engine for 400 dollars
btw where in toronto are u doing this? i also have a SOHC project rolling comming together, but i found a guy in aurora ( i live up in the boonies)
lazydude-t
04-21-2006 05:51 PM
lazydude-t
Texas -OK -LA (Sales)
04-21-2006 05:50 PM
ExospeedAMcrx
01-08-2003 03:58 PM
