B18C Crankshaft
Old 01-23-2005, 01:50 PM
TypeRcivic's Avatar
Default B18C Crankshaft
I have a fully built 98+ spec JDM ITR and I have replaced everything inside except for the crank. With running about 200 whp and about a 90 hp shot from a wet kit, do you think the stock type r crank will be strong enough or do I need to upgrade say with an eagle crank? Any ideas? I know this is an all motor site, I just want to know about the crank. Thanks
Old 01-23-2005, 02:53 PM
HONDABROMANDUDE's Avatar
Default Re: B18C Crankshaft (TypeRcivic)
Stock crank will suffice.
Old 01-23-2005, 04:05 PM
All Motor Mentor
00Red_SiR's Avatar
Default Re: B18C Crankshaft (HONDABROMANDUDE)
Yep, it's fine, it's already forged from the factory so it's definitely strong enough. Rods and Pistons would have been the main concern but you said your motor was built. Just out of curiosity, what comprssion ratio are you running?
Old 01-23-2005, 04:14 PM
jdmcx's Avatar
Default Re: B18C Crankshaft (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Yep, it's fine, it's already forged from the factory so it's definitely strong enough. Rods and Pistons would have been the main concern but you said your motor was built. Just out of curiosity, what comprssion ratio are you running?</TD></TR></TABLE>
get it balanced
Old 01-23-2005, 07:17 PM
slo blue's Avatar
Default Re: B18C Crankshaft (jdmcx)
the crank is the strong point of the b18. 200whp and 90shot
Old 01-23-2005, 07:18 PM
spooncivic1's Avatar
crower 92mm crank
Old 01-24-2005, 08:03 AM
TypeRcivic's Avatar
Thanks for the reply. I hve got a 98+ spec JDM ITR with Toda valvetrain,Spec C cams and Pistons. I recently upgraded the rods to the Eagle H-beam ones. I am running 12.5:1 cr now on 92 pump gas with the hondata s200 program. I just wondered while the motor was in pieces it would be cheaper to replace the crank if I needed it.
chueflee
10
07-06-2008 11:19 AM
SikofFalln
04-29-2007 03:42 PM
Stingray96
09-09-2005 10:51 AM
caspers_hatch
08-12-2005 09:35 PM
EK FLY
05-22-2005 09:14 PM
Quick Reply: B18C Crankshaft
