Really need help with ignition, engine gurus needed.
alright here is the situation. my motor is an itr head on gsr block, with obd-0 wiring, in a DA
With the distributor fully advanced, my motor is firing at 0 degrees. when the light flashes on the timing light, the white TDC mark is lined up with the mark on the cover.
I know it should be firing at 16 degrees BTDC, but I can't advance the distributor far enough to get there.
The car also doesn't advance when I'm at wot.
The car runs pretty well, good enough to daily drive but severely under powered.
yes I jumped the connector
Timing belt is on there right, cams and CS pulley are all lined up. my firing order is correct, 1,3,4,2. I've tried 3 different distributors, 8 different ECU's, and I rewired my entire car from dash to headlights. still the same problem
ek_James
08-31-2007 12:35 PM
forcefedferio
08-29-2006 11:06 AM
krazn
02-22-2004 11:11 AM
94gsr
10-24-2002 04:15 PM
