MACHINE OR REPLACE?????????
Old Sep 26, 2005 | 12:54 PM
planetstereo's Avatar
Default MACHINE OR REPLACE?????????
98 ITR B18C5, SPUN ROD BEARING CAN I GET AWAY WITH JUST GETTING THE CRANK TURNED 10/10 OR SHOULD I BUY OEM NEW????
Old Sep 26, 2005 | 01:01 PM
Player5530's Avatar
it depends on how bad the crank is scared. take it to a machine shop and see if they can micropolish it if not get a new crank. In my experience a cut crank is not as reliable as a uncut one.
Old Sep 26, 2005 | 05:25 PM
Default Re: (Player5530)
the crank was really not scarred much at all,if i micropolish it can i still use factory bearings new of course.i was thinking about getting it turned 10/10 but ive heard mixed opinions.what does everyone think????????????
Old Sep 28, 2005 | 08:34 AM
Player5530's Avatar
if the crank is not scared then you can use OEM bearings
Old Sep 28, 2005 | 12:21 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (planetstereo)
take it to a good machine shop and find out
Old Sep 28, 2005 | 09:23 PM
Tech6023's Avatar
Default Re: MACHINE OR REPLACE????????? (planetstereo)
get the one journal welded and turned to standard if it is bad
Old Sep 29, 2005 | 04:02 AM
JDMoMo
Guest
Posts: n/a
Default Re: MACHINE OR REPLACE????????? (Tech6023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tech6023 &raquo;</TD></TR><TR><TD CLASS="quote">get the one journal welded and turned to standard if it is bad</TD></TR></TABLE>
what he said. Thats what I did. They weld it and build it up to fit your bearings and NO it's not the same welding as welding two metals together, if thats what you're thinking. It will be cheaper for you rather than to get OEM crank
gdrum
Apr 6, 2017 06:57 AM
raverx3m
Sep 9, 2013 01:58 AM
ShortbusEK
Mar 7, 2008 01:29 PM
NetLogic
Dec 16, 2004 01:57 PM
bboy_gangsta
Feb 15, 2003 03:42 PM
