200whp b16?
200whp b16?
I'm new with building honda's, but I've built some other imports cars before! I've read through some of the older topics on 200whp on b16's. I was wondering would my setup be enough to get that power. Also, would this setup be pump gas friendly?
Jdm B16a
CTR pistons (stock bore)
Stock crank
Stock rods
ACT Prolite flywheel
Act 6 Puck Clutch
AEBS Intake Manifold
RC 310 injectors
70mm Throttle body
Hondata Intake Manifold Gasket
Password Jdm (J's Racing) Intake
Skunk2/HRD PR3 Head or PnP Head
Skunk2 Pro1+ Cams
Eibach Valvesprings
Supertech Retainers
Stock Type R Valves
STR Cam Gears
An-r Sidesweep Stainless Steel Header w/ Street Collector or Hytech header
Greedy SP2 Catback Exhaust
*This Setup is going into a Del Sol also. Your feedback would be great, so I dont end up getting things i dont need. Thanks
Modified by Flu_By_U at 11:02 PM 11/6/2005
Jdm B16a
Stock crank
Stock rods
Act 6 Puck Clutch
RC 310 injectors
70mm Throttle body
Skunk2 Pro1+ Cams
Eibach Valvesprings
Supertech Retainers
Stock Type R Valves
STR Cam Gears
Re: 200whp b16? (Flu_By_U)
If you are really using all that stuff you mentioned, then yeah 200 hp could be pretty possible, Some people might suggest on a bigger displacement.
But its pretty cool when you beat other cars with a B16 monsta.
B16 REv happy engine.
if you're new then by some chance you may not have heard of Omniman. Spend the money and get his video on his B16 buildup that makes 200whp and is street driven. Like a lot of people well also tell you, you'd be surprised how much the stock parts can actually handle. And with making any power, it's all in the headwork and tuning.
HT White Ops
Re: 200whp b16? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Good headwork is the key to successful engines.</TD></TR></TABLE>
futrhondaownr
10-11-2008 01:11 PM
4th-gen-civic
07-25-2007 04:31 PM
Wafler
07-19-2005 11:21 AM
C2Imports
30
07-19-2004 01:35 PM
