removing crank shaft
anyone have the best way to remove the crank? i have the pistons out and everything unbolted but cant figure how to remove it
Re: removing crank shaft (slowassciv33)
there are oil seals on both side of the block I belive to seal in the oil from outside, you probobly have to remove those. If you have check to make sure nothing else is holding it down and dently try to rock it out, or use a rubber mallet to help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 »</TD></TR><TR><TD CLASS="quote">i cant get the oil pump out </TD></TR></TABLE>
Why?
Why?
