96 Integra LS going to OBD1 quick question.
Old Dec 22, 2007 | 09:44 PM
integrawow's Avatar
Default 96 Integra LS going to OBD1 quick question.
I am under the assumption that with a bone stock 96 Integra LS 5-speed B18B, in order to convert to OBD1, I will need only the following:
-OBD2a to OBD1 ecu jumper harness
-OBD1 non-vtec distributor
Am I missing something? I know I may have to alternate some of the ecu pinouts to accommodate the use of other ecu's, but this will be or should be covered in the instruction manual provided with a jumper harness from a company such as Rywire.
Let me know. Thanks in advance.
Old Dec 23, 2007 | 05:47 AM
integrawow's Avatar
I have very limited amounts of time here. I mean, I know just about everything there is to know about DA integra's, but I know almost nothing about DC integra's. I've been researching since noon time yesterday about the OBD1 swap, but still can't put a definite answer on the drawing board.
Please let me know this.
Old Dec 23, 2007 | 10:50 AM
gibsanez's Avatar
Default Re: 96 Integra LS going to OBD1 quick question. (integrawow)
Just use your stock 92-93 engine harness on the OBD2 B18, if you hadn't planned on it already.
Old Dec 25, 2007 | 06:50 AM
Lee_eg6si's Avatar
You need the 94-95 fuel injectors(4x), 94-95 alternator, leave the distutor alone and use Distributor Jumper Harness (get it from password jdm), use a P75 Obd1 ecu and hope that you'll still have the accelerator cable from the 96 LS motor you'll need that too. Everything else will be a plug and play.
Old Dec 25, 2007 | 06:52 AM
integrawow's Avatar
Thank you to everyone who replied.
Old Dec 25, 2007 | 05:31 PM
integrawow's Avatar
What if I just bought the 96 spec GSR engine/trans/ecu instead of the OBD1 GSR engine/trans/ecu? Then all I would need is a subharness from Rywire, right?
Let me know.
Old Dec 26, 2007 | 09:06 PM
HAPRECYCLING's Avatar
Im using a 98 GSR in my 92 civic. Using all OBD2 parts..Harness,Distributor,Alternator,Fuel injectors,everything obd2 Just using an OBD1 ecu!
Old Dec 26, 2007 | 09:34 PM
egsleepercivic's Avatar
all you have to do is use the LS harness and plug it in to your civic and get an OBD1 LS ecu
gl
miamihonda
Dec 27, 2013 01:33 AM
Nisif
Oct 20, 2012 06:11 PM
integrawow
Dec 23, 2007 12:19 PM
4thgenlude
13
Oct 24, 2006 10:46 AM
ucc crx
15
Dec 17, 2005 05:04 PM
