Official oil pan ground clearance & Axle angle PICTURE Thread!
I started this thread on K20a.org Has turned out to be a pretty interesting thread with a few responses. I'm curious to how the B series axles / oil pan clearance compares to the K series.
I'd like to see 4 things in this thread:
1) Oil Pan ground clearance picture(s), and which specific oil pan you are using
2) Axle angle from tranny to hub pictures
3) Picture(s) w/ decription showing drop from fender above top of tire to ground
4) Chasis, motor swap, motor mounts used, and wheel size (suspension / axles optional info)
Car: 1995 VX
Engine: 2003 K20A2
Engine Mounts: Hasport EGK1
Oil Pan: Stock K20a2
Axles: 2003 Type S
Suspension: Ground Control coilovers (raised all the way up) / Koni Yellow shocks
Distance from top of fender to ground: 23 3/8"
Tires: Falken Azenis 205/50/15
Wheels: Konig Heliums
Passenger side axle angle:
Driver side axle angle:
Oil pan clearance to ground (3.75"):
Suspension drop pic:
Story behind this thread:
A guy at the Nopi Nationals approached me asking how my axles were surviving with such an angle from the tranny to hubs. He stated the axles were seeing a huge incline from the tranny to the hubs. Well I forgot to look at them because I was just having too much fun at the show Weeks went by and while working on the hatch I noticed my oil pan was pretty close to planet earth. So, I decided to raise the Ground Controls approximately 1" all around. This brought the car up to a 1 finger gap between the fender and top of the tire at all four corners. I went back to raise the car up only to find out the GC's were a couple turns away form being all the way up. So, now the height is set as high as possible.....
So post up those pics and specs
Car: 1995 VX
Engine: 2003 K20A2
Axles: 2003 Type S
