a/c and p/s with h2b conversion
Old Dec 13, 2007 | 04:42 AM
aus_newbie's Avatar
Default a/c and p/s with h2b conversion
Hi guys
Just wanted to know if you can retain a/c and p/s in ek civic when attempting a h2b conversion. Hope a h2b guru on H-T will help me out
thanks
Old Dec 13, 2007 | 05:34 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: a/c and p/s with h2b conversion (aus_newbie)
yes you can. anything is possible. make your own alternator and A/C brackets I would also move my crank pulley 1/2" to the passenger side white im at it let me know if you have any questions,Surge
Old Dec 14, 2007 | 08:52 PM
aus_newbie's Avatar
Do u know of any available kits out there to retain p/s and a/c or does it have to be custom made?
Also is there anyone running p/s and a/c with the h2b conversion on H-T, if so can u please post up some pics
thanks
Old Dec 14, 2007 | 10:40 PM
xv53's Avatar
Default Re: (aus_newbie)
i think its an either/or situtation because of the alternator being mounted on the front of the motor, it only leaves one space to mount the power steering pump or a/c compressor. there's a guy (ht screen name lak8) that did an h22 swap into an integra and made the a/c work using a modified hcp h22 to d series mount.
I am going to try to accomplish running an h2b into a 95 teg with a/c, I'm removing the power steering.
Old Dec 15, 2007 | 01:00 PM
high_revs's Avatar
its possible but not worth it in my opinion...too much fabbing and im not a fan of ac either way
Old Jan 1, 2008 | 10:45 AM
HondaBlock's Avatar
do you know where I can get a H2B conversion kit?
Old Jan 2, 2008 | 08:14 PM
thehatchninja's Avatar
obx makes them now check ebay.
Old Jan 2, 2008 | 08:16 PM
for real tho. I have heard of A/C being possible in an integra, and for the P/S you could always run an electric pump system instead of belt driven. I believe it's possible, but only if you're comfortable with a significant amount of fabricating.
92CivicEG3
Feb 9, 2012 01:57 AM
sir.hondchedda
Welding / Fabrication
Jul 14, 2010 10:16 AM
95dcsleeper
Jul 22, 2005 09:25 AM
95dcsleeper
Jul 22, 2005 09:24 AM
93eg-EKhybrid
Aug 13, 2002 02:39 PM
