H2B timing belt bracket
i bought a h22 motor and i was wonder what timing belt bracket and mount. Should i use a Gs-r or h22 and it's going into a EG.
Cause i was thinking of soldering the mount bracket
Ditto
https://honda-tech.com/zerothread?id=1475661
http://www.quartersportsdrag.com/FAQ.html
Most of your questions can be answered from those 2 links. Check the H2B FAQ in the hybrid forum for more info too.
King of the One Liners
Re: (StOnErTuNinG)
then you bought the kit without mounts buddy. Must buy the mounts from evo or if you look further down this forum hasport just released some
Re: (StOnErTuNinG)
I see broken axles in your future buddy.
the 2 different kits have different angles. I wouldnt try to make one yourself if i was you.
