DOES ANYONE KNOW THE ANSWER.
Old Dec 9, 2007 | 08:02 AM
boosted92hatch's Avatar
Default DOES ANYONE KNOW THE ANSWER.
hey whats up, ive been askin the same question for 6 days. can i use a d16z6 head and dizzy on a obd2 civic to replace a Y8 head and dizzy. i bent a valve and have a Z6 with really low miles. i know i just have to rein the dizzy plug but can i use this or will it run funny. please help
Old Dec 10, 2007 | 10:21 AM
1SiC 3DR's Avatar
Default Re: DOES ANYONE KNOW THE ANSWER. (boosted92hatch)
it will run fine as long as u repin it right, and use the proper plug off the Y8 timing will be off a half a tooth??? if i'm not mistakin
Old Dec 10, 2007 | 12:42 PM
Default Re: DOES ANYONE KNOW THE ANSWER. (1SiC 3DR)
will it be off by a half tooth retarted or advanced and can i make up for this with a adjustable cam gear. anywhere i can find the right place for the wires to go
Old Dec 10, 2007 | 01:43 PM
1SiC 3DR's Avatar
it will be advanced 1/2 a tooth and yes a cam gear will make up for it, and the wires on just about all honda's is bottom left is cylinder number 1, then 3,4,2 and it goes in a clockwise direction
Old Dec 10, 2007 | 04:33 PM
i mean the wires to repin the dizzy. what colors go where
Old Dec 11, 2007 | 04:59 AM
1SiC 3DR's Avatar
most of your wires will match up, you might have one light blue wire off of the obd 2 dizzy left over depending on year, but most of it should match, i have a D16Y8 in my DD with a repinned Y8 dizzy i had no issues
Old Dec 11, 2007 | 10:48 AM
hey thanks alot for all your help. i got it running but it is thowing a code all of a sudden for crank position sensor. and on 96-00 models its inside the timing cover , but on the z6 its inside the dizzy. so i dont know if i have 2 crank sensors running my car or what
Old Dec 12, 2007 | 05:43 AM
1SiC 3DR's Avatar
if you go to ff-squad.com it shows you how to bypass the crank sensor on 96-98 cars and 99-00 where basically it will see dizzy signal and adapts
Douglasjdm
Nov 17, 2013 02:11 PM
92lxsleeper
Jun 6, 2009 08:05 AM
philliecrx
Jul 13, 2005 07:46 AM
d15nonvtec
Sep 23, 2003 08:53 PM
stingray2772
Feb 17, 2003 10:12 AM
