JDM H23 VTEC fuel line HELP
King of the One Liners
Re: JDM H23 VTEC fuel line HELP (lutherd300)
Either get an aftermarket fuel rail that has openings on both sides so you can use the stock line, a 90-93 accord fuel rail, or make your own fuel line.
Re: JDM H23 VTEC fuel line HELP (2fastGSR)
Use your stock fuel rail.
Or
Cut down you old banjo end on the fuel filter side of the car's origional fuel line and then use the H23 Vtec's fuel rail banjo. You will have to find a shop that has just the right crimp piece to be able to re use your stock banjos you will need to strip your stock banjos down to metal, the hose can be a pain to get off heat and a knife works good. Finding the crimps I believe is what they are called may be a lil hard.
Napa sells FI fuel line and so does Schucks just make sure it's good for constant psi of 50-60.
Or
Re: JDM H23 VTEC fuel line HELP (ESP.net)
thanks for the info , I went down to a large hydrolic hose shop and they made me a custom fuelline with the bango ends i supplied for only 40 bucks and it is good for up to 3000 psi . like ill never need that much fuel pressure
