Is it possible to mate a B series motor to a D series tranny?
My friend was wondering. I think it would be possible with an adapter plate and what else? I know its pointless from a performance point of view but not having to get a B series tranny saves bucks....Cheap i know. Not for me.
Re: Is it possible to mate a B series motor to a D series tranny? (HBKFanatic)
No adaptor plate exists for this at this point in time. But I believe Bisimoto is working on one. Just consider that even when such a kit comes out, it is not going to be wihout its pitfalls. First of all, much like Bisimoto's other adaptor plate kits, it would probably not be priced very cheaply. Probably in the neighborhood of $600-$1000 (or so). And then, there is the issue of the driver side of the motor. At least in an ED/EF, the D-series bellhousing is closer to the driver side of the car than on a B-series transmission mounted with a Hasport kit by around an inch (or so). Add to this the fact that the adaptor plate is probably about .5 inch thick, and you could run into some clearance problems with the crankshaft pulley and possibly the timing belt cover. But even if these are not an issue, you will need to either buy or fabricate a driver side mount. Again, this is an additional bother and/or expense. All in all, it is probably not worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBKFanatic »</TD></TR><TR><TD CLASS="quote">My friend was wondering. I think it would be possible with an adapter plate and what else? I know its pointless from a performance point of view but not having to get a B series tranny saves bucks....Cheap i know. Not for me.</TD></TR></TABLE>
why? it would cost more than just buying a b series trans.. and be more of a hassle to run something that isnt as good???
so again...... why???
Re: Is it possible to mate a B series motor to a D series tranny? (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr »</TD></TR><TR><TD CLASS="quote">
so again...... why???</TD></TR></TABLE>
Especially when, for the cost of any adaptor plate, you can probably by two or three B-series transmssions.
Mr. Badwrench
Re: Is it possible to mate a B series motor to a D series tranny? (StorminMatt)
b motor to d tranny, i dont know of, but rota 92 has a d motor to b tranny or had i should say as he is stepping up in the world.
dc5mikeydc5
09-11-2005 02:09 PM
Blanket Jackson
01-16-2005 07:31 PM
i want a civic
11-13-2004 03:51 PM
Maddox
216
05-14-2004 05:07 AM
