The code 43 paradox
Old Jan 4, 2008 | 02:55 PM
Sk8ermane's Avatar
Default The code 43 paradox
Not really much of a paradox, but I have read that alcohol does not damage 02 sensors and I was steam cleaning my motor with some alcohol by misting it into the throttlebody, and although it runs better at wot, I have the code 43 with some closed loop bucking.
I did some online searching for a solution, and I see that the 02 is the usual suspect. I havent changed it yet, because I replaced the fuel filter since it needed to be changed and of course, not much improvement.
Of course I will never do this again due to the havoc it wrecked on my intake air temp sensor(which I had an extra sensor laying around), but it worked on my dsm in the past, and falacious reasoning lead me to try it on my honda.
Anyway it's a 94 civic ex with an ls swap running the ls ecu. I replaced the o2 sensor a couple months ago, so I would tend to think that it is in good shape, but no doubt, I did something wrong when I steam cleaned my motor with rubbing alcohol.
It only bucks in closed loop, and when it does, I floor it and it stabalizes. What do you think? I am leaning more towards an 02 sensor over the fuel pump, because although I hear o2 sensors are not damaged by alcohol, the problem started right after the ghetto de-carb. Lesson learned, but I would like some advice from experienced people. Thanks.
Old Jan 11, 2008 | 08:59 AM
Sk8ermane's Avatar
Default Re: The code 43 paradox (Sk8ermane)
I guess nobody knows or cares to help me on this board. Thanks anyway's though.
SlowB20z
Engine Management and Tuning
Dec 28, 2012 09:12 AM
xxstuntin4life
Feb 3, 2009 04:33 PM
northemt88
Nov 18, 2007 10:30 PM
rorik
Jun 19, 2007 10:13 AM
