ls/vtec what head?
Old Jan 22, 2008 | 07:13 PM
0930_SI's Avatar
Default ls/vtec what head?
If i'm building an ls/vtec wich head is better to use? B16 or a GSR head. And Why? I have an ls block with CTR pistons i got it for cheap, and im getting offers for both a 00 civic si head and a GSR. Thanx
Old Jan 22, 2008 | 08:01 PM
sikcivic95's Avatar
Default Re: ls/vtec what head? (0930_SI)
you have got to be kidding me !! omg research dude! its personal preferance anyway! good luck with that..
Old Jan 22, 2008 | 08:14 PM
sikcivic95's Avatar
Default Re: ls/vtec what head? (sikcivic95)
im sorry but i wasnt flaming you to bad.. just research is all im trying to say before you ask questions like this.. people will do worse than what i just said.. sorry but still man... okay "they say b16s flow better", they also say" gsrs have better combustion chambers", but they also say "b16 heads are just plain better than GSR heads".. if your going to port and polish and build it up then it doesnt really matter which one you go with.. but if your keeping it stock then its up to you entirely.. i personally have rocket motorsports valvtrain and m22x cams,ported and polished GSR.. but im also using a high compression piston'd b20 bottom end and the 1.8 combustion chamber from GSR is larger for the 2.0 block instead of 1.6 b16.. so theres my imput.. okay hope that helps!
Old Jan 22, 2008 | 08:21 PM
0930_SI's Avatar
It does, Thanx
Old Jan 22, 2008 | 10:00 PM
cB7KiD's Avatar
best head to use would be a d16z6 head... its vtec.,..
Old Apr 13, 2008 | 12:53 PM
96int3gra's Avatar
B16 FOR LOWER COMPRESSION....
Old Apr 14, 2008 | 06:09 PM
SONAMBULO's Avatar
Default Re: ls/vtec what head? (cB7KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cB7KiD &raquo;</TD></TR><TR><TD CLASS="quote">best head to use would be a d16z6 head... its vtec.,..</TD></TR></TABLE>
lol
Old Apr 17, 2008 | 10:17 AM
Frenshawas's Avatar
Default Re: ls/vtec what head? (SONAMBULO)
the b16 for boost if thats the way your going but for a n/a set up i would use the gsr
Old Apr 18, 2008 | 10:09 PM
randomnineh2b's Avatar
hey man you from cali, well i got a gsr head that i want to trade so let me know
Old May 20, 2008 | 02:48 PM
sk8erboii's Avatar
haha..a D-series on a B-series???
we have a noob here
Old May 20, 2008 | 02:49 PM
sk8erboii's Avatar
Default Re: ls/vtec what head? (sk8erboii)
go GSR head..better compression and top end
Old May 22, 2008 | 06:50 AM
bakomack's Avatar
im in the process of building a ls/v right now, im starting from scratch with a clean 94 ls block and a complete but blown up 94 ls motor. I was told for all motor gsr would be better in the long run so im trying to find one right now, where at in cali you live?
Old May 22, 2008 | 08:48 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0930_SI &raquo;</TD></TR><TR><TD CLASS="quote">If i'm building an ls/vtec wich head is better to use? B16 or a GSR head. And Why? I have an ls block with CTR pistons i got it for cheap, and im getting offers for both a 00 civic si head and a GSR. Thanx </TD></TR></TABLE>
with CTR pistons and a GSR head you will have very high compression. it will be pretty difficult to run on pump gas due to the combustion chamber design on the GSR head. the B16 head will be lower compression. If anything please get this tuned.
a set of cams will bleed off some of the compression. I'd personally go with the B16 head for a daily driver on pump gas. and make sure to get it tuned or i can guarantee it will be blown up quickly.
TeGGY_LS
Oct 9, 2022 07:50 AM
hatchyAllday
Feb 27, 2008 04:02 AM
DAintegra
Dec 1, 2004 02:37 PM
No
15
May 14, 2004 01:08 PM
baonest
Apr 21, 2002 07:05 PM
