I need a Pinout Tool!
Does anyone know where you can find one of these. I've searched the web and HT and very few people know what i'm talking about and no one knows where to get it. I already have the Skunk2 jumper harness but the smog referee is being a &^% and is saying i got to straight wire it.
This tool slides into the wireharness blocks allowing you to remove the wires with the connections intacted.
Any help would be appreciated.
Re: (ekb16)
I started with a peace of wire that i hammered flat then shaped to fit it. It worked but not nearly good enough to do like 50-60 wires with. I guess I'll start with something a little thinner and see what happens. thanks
Re: (toyomatt84)
Just go buy one of those precision screw driver sets, those small 6 piece watch screwdriver sets, and use the smallest one I got my whole set for $6 from the local hardware store
Re: (toyomatt84)
Thanks for the link, but i can't get the pics to enlarge so i can see which one it is. If they are indeed the tool it looks like it would be the Female remover right.?
Re: (toyomatt84)
Well, thanks for all the info guys. I got it done. It took longer than i would have liked but this kind of stuff always does.
So, the final solution. One precision screw driver (ground down to make it even smaller) and a second set of hands (60 yr old dad) pulling the wire out of the back while i held the block in one hand and pushed the clip down with the other.
Result. Completely repinned to 99-00 Ecu no codes and ready for that smog ref. *****!
